Results 1 to 4 of 4
    Default 2010 Mini Cooper R56 Dme Clone Used
    BOSCH 7601756
    2010 mini cooper s turbo
    tricore tc1766
    I am trying to clone this ecu from original to used donor using ktag boot mode. After cloning eeprom and flash i receive error in diagnosis for ews tampering and no start. I have seen others on the forum have this problem with this particular car. I have seen some people modify something with isn to resolve this issue.
    Any help appreciated. Thank You.
    attached dme original and donor
    Dec 2018
    Hi. Try to upload a backup from Ktag. If you upload separately, you will not lose the secured area. And the car did not start.
    I tried both ways, save files separate then write, and also save as backup and write, both ways the isn does not transfer to replacement dme
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by peter006 View Post
    your missing/incomplete files, a med17.2 does have tc1766 int_eeprom 128kb also for what i know
    also indeed password protected in boot so you need ori tools to do this
