Results 1 to 15 of 16
    Dec 2018
    Default Hextag / Hexprprog
    A friend read some eeproms with the clip adapter from xhorse and hextag. He said there are a lot of eeproms where you must lift a leg with xhorse but with hextag not. Has hextag a special procedure for that problem?
    is in worth to buy the hexprog instead of hextag?
    Mar 2018
    UK
    Hextag and Hexprog are like VVDI Prog and VVDI2
    They do different things - Prog is programmer to read and wriite eeproms and mcu
    Hextag is mostly OBD tool to program keys by OBD
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    Alpaholic (10th November, 2021)
    Dec 2018
    But is it true that hexprog can read spi eeproms without lifting a leg?
    Mar 2018
    UK
    Quote Originally Posted by Alpaholic View Post
    I use Hextag only for BMW key programing and read and write FEM BDC on circuit fine
  6. The Following User Says Thank You to Manta1600 For This Useful Post:
    fred77's Avatar
    Jun 2019
    now this is interesting....
    my personal experience is the AutoHex clip is the ONLY quality one - 3M
    saying that I ONLY USE for FEM modules. So maybe others say different
    Thrown all clips in bin from Autel, XHorse, etc
    best if you invest in hot air gun as removing is safer (in my view). Good luck
    Solidarity with Ukraine
  8. #6
    Mar 2018
    UK
    Quote Originally Posted by fred77 View Post
    Autel clip went in the bin just after few months - now I use Pomona clip that is not too bad
    I use hot gun only on old mercedes MCU all eepromes that need to read I read them on circuit without lift the legs
  9. The Following User Says Thank You to Manta1600 For This Useful Post:
    fred77 (11th November, 2021)
  10. #7
    Jan 2019
    United Kingdom
    Quote Originally Posted by Manta1600 View Post
    Rule no 1 in programming, always remove eeprom, We become lazy to read in circuit but how many times do we see threads about something gone wrong, cluster data corrupted etc etc
    i always remove, prefer it, atleast i know my read is good, some eeproms when using clip send power to processor which again can damage cluster airbag module or whatever your working with, hence why DP4 have diagrams to make a bridge before reading in circuit which kills the power to processor, Yet still many still kill eeprom data with DP4, best is 30 seconds heat & remove
  11. The Following 3 Users Say Thank You to amar28 For This Useful Post:
    fred77 (13th November, 2021), jodge (11th November, 2021), neuro (13th November, 2021)
  12. #8
    Apr 2019
    Apr 2019
    Do you know where to buy a new 3M clip? Mine is worn out and Microtronic only sell the whole cablage.
  14. #10
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by mjoesen View Post
    pomona 5250…
    use google…
  15. #11
    Apr 2019
    I have Pomona whant a genuine 3M
  16. #12
    Mar 2018
    UK
    I have Pomona what a genuine 3M
    I don't think that pomona is the same quality like 3M
    https://uk.farnell.com/3m/923655-08/...old/dp/2396057
  17. The Following User Says Thank You to Manta1600 For This Useful Post:
    mjoesen (12th November, 2021)
  18. #13
    Dec 2018
    https://www.arlabs.com/adapters.html...eeprom_adapter
    I found this adapter with a voltage switch. Is this make the readings safer?
    IN-CIRCUIT SERIAL EEPROM ADAPTER
    Part #ASERSM1A
    - $59.00
  19. #14
    Hungary, Mosonmagyar?v
    I have both , You have right 3M is better quality as ponoma .
  20. The Following User Says Thank You to kareszka For This Useful Post:
    mjoesen (14th November, 2021)
  21. #15
    fred77's Avatar
    Jun 2019
    As said remove chip.
    messing with eeproms should be taken seriously as you could cause thousand of pounds/dollars damage in seconds.
  22. The Following User Says Thank You to fred77 For This Useful Post:
    Alpaholic (13th November, 2021)
