Results 1 to 9 of 9
    macako6's Avatar
    Mar 2015
    Default BMW F10 Airbag error 930ABD internal fault
    Hi, I have a problem with the Airbag module, it is a BMW F10 car from 2012
    -Airbag module Continental
    -ACSM4 65.77-9253637-01
    -BMW NR : 31925363701U
    i need a clean file or if anyone can fix this D flash
    USA,UKRAINE
    Hi try and report
    Pass in PM
    If I helped, please use reputation+thanks button
  3. The Following User Says Thank You to slavik For This Useful Post:
    macako6 (13th November, 2021)
    macako6's Avatar
    Mar 2015
    Thank you friend for the help offered but the problem remains.
    The error is still there
    USA,UKRAINE
    Hi can you read as p-flash and post it
    macako6's Avatar
    Mar 2015
    Yes, I have also read P Flash
    macako6's Avatar
    Mar 2015
    I tried all the options I have available, 1. I tried to write another D flash file from another module with the same numbers then this error does not exist but there are other errors that there are in the other vehicle crash, belts tension and others. 2. I tried to reflect it with e-sys but uselessly they are the same again.
    USA,UKRAINE
    Hi write this P-Flash reset file and then read as D-Flash and post D-Flash here Check instruction
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by slavik View Post
    not possible read , after reset i try
  10. #9
    macako6's Avatar
    Mar 2015
    These are the files I read after writing P-Flash as well as the errors when I connected it to the vehicle
