Results 1 to 11 of 11
    fuzz1's Avatar
    Jul 2019
    Default Brush cutter dies out when accelerating
    Today after a few weeks switched on my brush cutter. Switch on fine but dies out when accelerating.
    It is a two stroke engine i admit i put a bit more oil in the fuel.
    Wondering if that could be the cause.
    Cleaned the spark plug didn't work
    Can the carburetor be cleaned by spraying directly through it like in the cars?
    Meat-Head's Avatar
    Sounds like that shit E10 fuel has clogged main jet.
    spray yes, cant see why not.
    if was me, leave running 6minutes, then put some sunglasses on, baseball cap backwards
    in macdonalds carpark, then try your best to get it to rev by on/off the gas, then on/off the choke
    if you get it running fast, hold throttle high, on/off with choke to suck gummed fuel out
    some carbs are like £9 delivered from china, ebay bolt on.
    avoid paint thinners, If your bored, take carb off E5 fuel , leave in jamjar of it
    next time you use it, run it out if fuel
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    fuzz1 (14th November, 2021)
    fuzz1's Avatar
    Jul 2019
    Definitely it's not fuel with ethanol though. I am however using a new two stroke oil. Never used before. Don't feel like dismantling the carb just now. With my luck I'm afraid to tear the diaphragm
    Meat-Head's Avatar
    1) look on eBay for carb
    2). Possible piston ring gummed up, fill with neat petrol, plug in, leave overnight
    Drain out, squirt some UB40 in it, try again
    3) ADVERTISEMENT “gunson color tune” but you will cough at the price
    Anyone will
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    fuzz1 (15th January, 2022)
    Rider667's Avatar
    Feb 2020
    my MC saddle
    try to change fuel,no more oil than 25ml/L of fuel...too much oil will clogging the exhaust,hard start,poor acceleration.
  8. The Following User Says Thank You to Rider667 For This Useful Post:
    fuzz1 (15th November, 2021)
  9. #6
    fuzz1's Avatar
    Jul 2019
    Yep definitely think I put too much oil did not think that would have such a dramatic effect. Thought it would just be black smoke
  10. #7
    Meat-Head's Avatar
    Can you tell what it is yet?
  11. #8
    fuzz1's Avatar
    Jul 2019
    I gave up on it. Sent it to a technician said carburetor needs to be changed. Sent it to another said only cleaning was required and works somehow. He didn't even take any money as compared to the first one who didn't do anything.
    I opened to check the muffler was surprised to see that there was no flame arrestor in it
  12. The Following User Says Thank You to fuzz1 For This Useful Post:
    Meat-Head (15th December, 2021)
  13. #9
    Jun 2022
    Quote Originally Posted by fuzz1 View Post
    Had the same situation with a lawn mower. I contacted the https://worx.pissedconsumer.com/customer-service.html, but they claimed it was no longer repairable under warranty. So I sent it to a technician, they held it for two weeks, told me they changed carburetor. When received it back, it worked for another week and broke.
  14. #10
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by Ainsley View Post
    Had the same situation with a lawn mover.
    What brings you on dk?
  15. #11
    Meat-Head's Avatar
    would expect answer to be a computer
