Results 1 to 5 of 5
    DK Veteran dollarbill's Avatar
    france,paris
    Default W168 PROBLEM IMMO MSM 2.0 AND IMMOBOX 1688200426
    HI FOR ALL
    I HAVE PROBLEM WITH IMMOBOX W168 1688200426 IN THE IMMOBOX THE CAR SOMETIME START AND SOME TIME DON'T START BUT I HAVE NOT START ERROR IN DASH BUT I HAVE FAULT CODE
    B1000 CONTROL MODUL FFZ N54/3
    B1101 SECURE SN2 CONTROL CABLE PSE/CL CF ANTITHEFT ALARM SYSTEM
    I HAVE BUY ANTOTHER IMMOBOX I PUT THE DUMP OF ORI 1D69J BUT IS THE SAME FAULT IN SECOND IMMOBOX I HAVE TWO KEY AND I MAKE THE KEY WITH ABRITES BUT IS THE SAME I THINK THE PROBLEM IS THE DUMP THE CAR HAVE ECU MSM2.0 1661411325 NO FAULT IN THIS
    IF SOMEONE CAN REPAIR THE DUMP OR GIVE ME SOLUTION FOR IMMO OFF ON THIS ECU I HAVE A JULIE EMULATOR BUT I CAN'T SEE HOW TO CONNECT BIG THANS IN ADVANCE
    if i help don't forget a thanks
    skens's Avatar
    Zagreb,Croatia
    hi
    use star diag, HHT win
    uses synchronization, write down the configuration beforehand!!
    gasoline cars have no start error
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  3. The Following User Says Thank You to skens For This Useful Post:
    dollarbill (18th November, 2021)
    france,paris
    THANKS I MAKE IT VIRGIN AND PROGRAM WITH DAS THE VEHICULE WORK GOOD TWO DAY AND IT DONE AGAIN THE SAME THING IS IT IS POSSIBLE AN EMULATOR ON THIS ECU
    france,paris
    I search ecu kit wsp + key + ecu but i don’t find If i buy only wsp with key i can sync with my ecu thanks for aswer
    Dec 2019
    if the key chip really fits wsp, then you will have to read the ecu eeprom, convert it to virgin , write to eeprom and do ecu initial startup with sd connect
