I have a big issue with a Citroen C3 1.4i 2004.
I have tried most of the things, even immo off but dont know for sure it was done correctly or what the next step will be.
Original BSI + ECU files + 2 version immo off attached below.
This car have hard time starting because of the U-fault codes, problem in CAN network and absence of communication with ECU/BSI and other units with can protocol in car.
I tracked down a fault to ABS connector wich was filled with grease so I cleaned it and put all things togheter, started the car and all faults erased automaticly by themselves.
But this have happen before as well, before I cleaned the plug.. Next time a person want to start the car it throws same fault codes again and again, car will be very very very difficult to start.
I have tried making immo off, changed bsi, ecu, coded keys, cleaned abs plug, stripped wires to see if something is loose/cut, cleaned all earth points to chassi and other parts of the car, checked all fuses...
Nothing seem to work, maybe someone here have been in same situation / same fault codes ?
Or is it a way to bypass CAN somehow with emulator or by cables?
ABS:
U1000
U1308
U1318
ECU:
U1000 - Communication between the engine management ECU and the other ECUs on the network (CAN)
P0568 - Cruise Control Set Signal Malfunction
P0571 - Cruise Control
BSI:
87C - Absence of Communication with the Engine Management ECU
CAR INFO:
Citroen C3
1.4i
2004
Engine code: KFV (TU3JP)
Thank you for all the help.
Best regards,
DeLuXe
