Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Default VW Golf VI VDO cluster repair
    Hello ,
    I have a car that came in with a dead cluster : no lights , no communication , IMMO active . Checked power supply & wiring to cluster , all is ok . On closer inspection the cluster has been removed before and it has been opened (probably to adjust mileage) . The owner insists the cluster died when the battery drained out . I suspect a corrupt dump . Can somebody check the 24LC32 dump to see if it's ok or not ?
    The part number is 5K0920870C , SW0029 , HW H21 . The car is 2009 2.0l diesel DSG. ump from 24LC32 attached , thank you.
    Oct 2014
    Netherlands
    Dump looks OK, so I think the problem is related to the cluster hardware.
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    cd_contact (24th November, 2021)
    rafal's Avatar
    UK - PL
    try resolder whole pcb by hot gun.............
    need help
    now my goal is to buy xp-005
    who will help?
  5. The Following 2 Users Say Thank You to rafal For This Useful Post:
    budata (24th November, 2021), cd_contact (24th November, 2021)
  6. #4
    I already tried reheating the board - no luck . If I get a used part with same HW and SW and get the dump from it - can I make a good dump from the 2 (original and "new") ?
    Thank you.
    Oct 2014
    Netherlands
    No, the immo data is uniquely encrypted inside the eeprom so a simply eeprom swap will not work.
    You can try to swap both the NEC and the 24C32 eeprom from orig dead cluster to the donor, if the NEC is not damaged it should work. At least if communications is working you could read full immo data.
    You can also try and get partial immo from the engine ecu and write it to donor cluster. Then adapt new keys and that should be sufficient.
    What engine ecu partnr is used? Do you have tools to read ecu eeprom?
    Rgs H2Deetoo
  8. The Following User Says Thank You to H2Deetoo For This Useful Post:
  9. #6
    Smart66's Avatar
    Dec 2020
    E2P looks good, mileage is 294 144 km. Did you check cluster's DTCs using VCDS?
    @H2Deetoo
    How is possible to read NEC flash from this cluster?
  10. The Following User Says Thank You to Smart66 For This Useful Post:
  11. #7
    Oct 2014
    Netherlands
    @Smart66 the TS said there wasn't any comms.
    Normally the NEC is locked so reading flash is not possible.
    You can only read flash if the cluster is communicating and you can unlock it.
    When I said swapping NEC I really meant swapping the NEC chip.
    This often works, at least to make a donor cluster working to be able to read it then.
  12. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    cd_contact (24th November, 2021), rafal (24th November, 2021)
  13. #8
    Smart66's Avatar
    Dec 2020
    It isn't possible to clone cluster without messing with NEC flash? Chip desoldering is really complicated
    Where are keys stored in cluster? Only in NEC?
  14. The Following User Says Thank You to Smart66 For This Useful Post:
  15. #9
    Oct 2014
    Netherlands
    Immo data is stored encrypted in eeprom and the key for that is in the NEC flash.
    In this case, when no comms is possible, swapping NEC is good option. If you have some skills with soldering then it isn't a big problem.
  16. The Following User Says Thank You to H2Deetoo For This Useful Post:
  17. #10
    Quote Originally Posted by H2Deetoo View Post
    I found a used cluster and when I receive it I will try swapping both the EEPROM and the NEC . In case the board itself (from the original cluster) is faulty this should work . If the NEC is faulty then I will try to read EDC17 EEPROM and come back to you.
    Feedback as sson as I have the "new" cluster. Thanks
  18. #11
    Smart66's Avatar
    Dec 2020
    Are part numbers same from these two clusters?
  19. #12
    Oct 2014
    Netherlands
    Cluster partnumbers don't matter.
    If both cluster have the same NEC cpu (70F3426 f.e.) then you can swap them and you should be able to get communications again.
  20. The Following User Says Thank You to H2Deetoo For This Useful Post:
    Smart66 (24th November, 2021)
  21. #13
    Smart66's Avatar
    Dec 2020
    Which tool are you using to unlock this NEC?
  22. #14
    Oct 2014
    Netherlands
    Any cluster tool will unlock the cluster to be able to read/write immo or mileage. Don't confuse it with unlock the NEC when reading it directly.
  23. The Following User Says Thank You to H2Deetoo For This Useful Post:
  24. #15
    Smart66's Avatar
    Dec 2020
    As far as I know mileage is stored in E2P. What is stored in NEC? Only IMMO area?
