    Default Autoboss V30 Screen problem Help.........
    Hi all,
    I have Autoboss V30 scanner that I bought from China. There is a problem that I have since yesterday: the screen is frozen, so I cannot use the touch pen??!!!! Any body experienced something similar?
    Any suggestions would be greatly appreciated.
    Thanx
    Quote Originally Posted by raddi View Post
    Hi all,
    Thanx
    Hi, had this happen to one, needed a new screen unit
    HTH
    If the lcd is not broken , you have the problem with the touch screen .
    Question
    Quote Originally Posted by diagsrus View Post
    HTH
    i have the same issue. i figured it was going to be a screen problem.do you know were i can find a replacement screen?
    that would be helpful thanks.
    Well, I took mine to a repair shop, and they think it is the screen. They are looking for a screen now. Got a hold of the seller in China.......will see what happens.
    Member stefan's Avatar
    Default problem with Autoboss
    I do not think that there is a problem with the screen.
    More likely it is one of soft cables carrying out the connection between boards is not good clip in its plug.
