Results 1 to 7 of 7
    Feb 2019
    Default Chrysler Crossfire 1D69J Dump Tango Unknown Version
    Read it using XPROG, original TANGO spitting out Unknown Version.
    I read it again with another programmer and the data is identical.
    I did 2 in the past with Tango and didn't have any problems.
    What could be the problem?
    Can someone check and see if dump is corrupted & can be fixed?
    igorr's Avatar
    Aug 2010
    Did someone tray to add key thru obd
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by looneyman View Post
    Heheh, you're either suffering the X-prog read curse or the eeprom does indeed have errors. Either way, write to the mcu and make your key from this one.
    <---- Coin of the Realm.
  4. The Following 4 Users Say Thank You to droidwayne65 For This Useful Post:
    Audis4b8 (7th November, 2024), looneyman (4th January, 2022), richard27 (30th July, 2024), srsreset (4th May, 2023)
    Feb 2019
    Worked, thank you!
    Aug 2015
    North America
    Worked, thank you!
    Good to hear.
    Jul 2024
    hey mr droidwayne65
    if i post my file could you check it ?
    carl
    Oct 2024
    hey can i please have the password for the fix i dealing with a nightmare. thanks
