Results 1 to 14 of 14
    Default vag/pin skc from my cluster eprom file
    hi, im new here, i hope that somebody can help me, i need find my sck from my dump, i read the eprom form my cluster and i have hex file, anybody knows how can i get my sck from this file, some calculator....
    my eprom is 24c32 and is on jetta 2009
    this is my dump
    Member lucianica's Avatar
    Bucharest/Romania
    nobody can calculate from dash
    read eeprom from engine control unit
    regards
    Quote Originally Posted by lucianica View Post
    regards
    thanks so i need read the eprom from my ecu??? i read that commander read sck code from dash i dont know can you help me?? what eprom i need to read to get my skc
    Bucharest/Romania
    original can commander can read eprom and pin from engine ecu
    waht engine do you have
    mult be spi eeprom 95160/95320
    regards
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by vtvw View Post
    95320...in the ECU mate ......
    ok, now, i have commander and tacho and cant read securyti code from my ecu and my cluster kombiinstruments, so i try to get this code to program my keys en swap my cluster, i thing ths is inmo 3, what program or interfase can do that, or a least read eprom by obd, i have external programer to rear/write eproms but is not odb
    Moderator
    PremierD's Avatar
    Jun 2009
    I think you will find that you need to open up the ecu.... and remove eeprom .... and read with your non obd reader mate .......sorry
    It's immo-4 and, i think, you will not be able to adapt key unless you have original K+CAN commander (AVDI) with open special function "Key learning". VCDS will not help you also even you know your login.
    Quote Originally Posted by Alex789 View Post
    It's im*o-4 and, i think, you will not be able to adapt key unless you have original K+CAN commander (AVDI) with open special function "Key learning". VCDS will not help you also even you know your login.
    thats rigth, in try to find my sck security code key to login and swap mi cluster anbd adpat my keys, where can i buy original k+can commander???
    regards
    ok, where can i see this number or where can i find?? sorry but im new
    my ecu engine es part 07k 906 032 BL
    my central elct. is part 3c8 937 049 D bordentz-sg
    You need to follow as above mate. Desolder the chips off your ECU otherwise you are getting nowhere....
    Post djamel
    code radio jaguar aj9150r
  13. #13
    regards
    But how can I read an SKC from an ECU immo dump???? or ecu on bench???
  14. #14
    Post djamel
