Results 1 to 11 of 11
    May 2018
    Default P160A Ford Escape
    Dear members,
    I have several codes when I scan the Ford escape. The first is P160A , CONTROL MODULE VEHICLE OPTIONS RECONFIGURATION ERROR. The ECM was replaced by another mechanic, now I believe that it needs more configuration
    Car drives fine, but 'Transmission fault' message keeps popping on the dash.
    Please members, how can I solve this problem?
    MahoJohn's Avatar
    Jun 2021
    which tools you use?
    May 2018
    I have Thinkdiag, Ktag, kess, Lonsdor K518E, Xtool Pro2
    Digital Under's Avatar
    Oct 2017
    Quote Originally Posted by Ter View Post
    as variant disable dtc code in flash ecu
    GM FORD DODGE
    tuning - deleting - immo
  5. The Following User Says Thank You to Digital Under For This Useful Post:
    Ter (11th January, 2022)
    May 2018
    How can I do this sir?
    MahoJohn's Avatar
    Jun 2021
    the easiest way is really to try for clearing the dtc. post file here, and then i will clear it. i hope the will function. after we look
    Oct 2017
    first need to find out which control unit is installed
    then find suitable reading tool and read flash
    disable dtc code and write file back in ecu
    enjoy!
    GM FORD DODGE
  9. The Following User Says Thank You to Digital Under For This Useful Post:
  10. #8
    May 2018
    Default ECM photo attachment
    I have attached a picture of the ECM for clarity and help.
  11. #9
    May 2018
    This code is also present. U0422(00) Invalid data received - body control module.
  12. #10
    Oct 2017
    Medg17.0
    Not sure about china clones but origunal kess and ktag work fine with this ecu type
    GM FORD DODGE
  13. The Following User Says Thank You to Digital Under For This Useful Post:
    Ter (12th January, 2022)
  14. #11
    May 2018
    This makes a lot of meaning. My ktag works just fine. Can do the job.
    Please can I have the pin out for BDM connection?
    Also, the message showing on dash "transmission fault. Service now" will go away? There are no fault codes in TCM.
    These are the codes present when I scan. Can we delete all of them if I am able to read ECM? Car drives fine.
    ============1==============P160A(00)Raw code: 160A00ECU: Engine control unitStatus: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clearFord: CONTROL MODULE VEHICLE OPTIONS RECONFIGURATION ERROR============2==============P26AC(00)Raw code: 26AC00ECU: Engine control unitStatus: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested============3==============U0422(00)Raw code: C42200ECU: Engine control unitStatus: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clearOBDII: Invalid data received - body control module============4==============P0011(00)Raw code: 001100ECU: Engine control unitStatus: Test not completed during this operation cycleOBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance============5==============P0012(00)Raw code: 001200ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-retarded============6==============P0014(00)Raw code: 001400ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-advanced/system performance============7==============P0015(00)Raw code: 001500ECU: Engine control unitStatus: Test not completed during this operation cycleOBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-retarded============8==============P0053(00)Raw code: 005300ECU: Engine control unitStatus: Test not completed during this operation cycleOBDII: Heated oxygen sensor (HO2S), bank 1, sensor 1 - heater resistance============9==============P0054(00)Raw code: 005400ECU: Engine control unitStatus: Test not completed during this operation cycleOBDII: Heated oxygen sensor (HO2S), bank 1, sensor 2 - heater resistance============10==============P007B(00)Raw code: 007B00ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Turbocharger (TC) intercooler temperature sensor, bank 1 - circuit range/performance============11==============P0087(00)Ra w code: 008700ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Fuel rail/system pressure too low============12==============P0088(00)Raw code: 008800ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Fuel rail/system pressure too high============13==============P008A(00)Raw code: 008A00ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Low pressure fuel system - pressure too low============14==============P008B(00)Raw code: 008B00ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Low pressure fuel system - pressure too high============15==============P00CE(00)Raw code: 00CE00ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Intake air temperature (IAT) measurement system - multiple sensor correlation============16==============P0106(00)Ra w code: 010600ECU: Engine control unitStatus: Test not completed since last DTC clear, Test not completed during this operation cycleOBDII: Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - range/performance problemFord: MAP/BP Sensor Range/Performance Problem============17==============P0111(00)Raw code: 011100ECU: Engine control unitStatus: Test not completed since last DTC clear, Test n
