    Default KIA CARNIVAL 2.9 crdi no immo lamp
    Hi i have trouble with kia carnival 2.9 crdi im*o.When i turn ignition on not have im*o lamp on dashboard and car wont start.I think its problem in wiring.Please if someone can upload wiring diagram for that car.
    Or if someone have cleared dump for engine ecu.ECU is delphi with
    95080 memory inside.
    i cheked on google that is trouble on a loot of carnivals but not founded solutions.
    Thanks in advance for help.
    Hi Under the dash by the steering wheel there should be a black box about 2/3 inch square Have a look at the red/blue wire it should have 12 volts to it .If not try a wire from a live feed(put an inline fuse in the wire) and put it down th side of the red/blue wire and turn ignition on and see if imob light comes on. If it does then the problem lies along tht wire or you can just scotch blok the 2 wires together
    Meat-Head's Avatar
    Quote Originally Posted by bruno1925 View Post
    I.D.C Insulation Displacement Connector or I Don't Care connector, the guy want's it fixing properly, not a fix that will last a year or not at all.
    M-H-M DO NOT use this type of connector, although we do have a smalll box of them for people we don't like.
    I would imagine the guy wants the car to start first and foremost. When its started he can then look at the options for making a permenant repair. Noticed you didn't offer a fix just critisism, very easy to do
    Nov 2010
    france
    IT S DIFFICULT
    Meat-Head's Avatar
    I have noticed you have nearly as many posts as downloads!
    Have you not noticed my 4727 other posts?
    Oh after 6 months suspect the car has been junked by now
    Meaty.
