Results 1 to 15 of 16
    Jan 2019
    Default Megane 2 1.5 dci 2004 water in diesel detector
    HI,
    I have a megane 2 without water in diesel detector fitted, but I have this dtcs.
    Can someone erase it from ecu dump ?
    I can save dump via renolink china obd clone and also rewrite with dtcs off ? DF057 is my problem.
    Also on dash appears check fuel filter, but filter is replaced already.
    Also, I reset crash data from airbag, but some dtcs still persist.
    Dec 2018
    Hi. This probably has nothing to do with resetting an airbag crash. At the bottom of the fuel filter you have a water sensor. Unscrew it and drain the contents of the fuel filter. Screw the sensor back in (preferably replace the fuel filter right away) They should clear the DTCs normally. Best regards
    Jan 2019
    Mine does not have fuel sensor, Also no water because is new, car works fine.
    I just want to delete this in flash from ECM
    Mar 2020
    in the field
    canclip should help, possible short circuit on the plug prepared for the water sensor
    Jan 2019
    it does not have a plug for this "function"
    I have renolink only It can be done with this but I do not know french
    Mar 2020
    in the field
    Default megane 1.5
    see if you have the wires led out?
    Jan 2019
    Does not seem to be the same. This is the only plug which is not plugged in something.
    Engine type: K9K722
    Mar 2020
    in the field
    looks like it's such a cube I'm not sure. try to combine pin 2 with the mass in a safe way
    by bulb 21w
    Dec 2018
    Most PSA has a 3-pin sensor, as the resistor would have to give it to lower the signal (1Koh). Peugeot has 9v on the signal with the plug unplugged. The other two are ground and 12V power supply.
    Jan 2019
    but 1.5 dci is not from PSA I think, what this plug would be?
    Mar 2020
    in the field
    just check pin2 if it is in the connector of the b3 controller, look for such a sensor .you don't have to screw it in
    Jan 2019
    it does not have water sensor my car.
    Can some one dtcs of this df057 if I upload here the dump ?
  13. #13
    Dec 2018
    Quote Originally Posted by Andr33iy98 View Post
    I understand. It didn't activate itself after all. Try to connect a different tester. Not that this one misleads you and gives you other errors. See what tension you have on this ankle as shown in the photo. Or see if there is a free cube somewhere near the fuel filter. Can be excluded from the file. Where is the file? It won't read itself.
  14. #14
    Mar 2020
    in the field
    how do you think? elektronik325 it looks like this plug probably shorted wiresAttachment 864201
  15. #15
    Dec 2018
    Rather not alone. See that there is a new fuel filter installed. A reputable company. And the plug for the sensor is at the bottom with three pins.
  16. The Following User Says Thank You to elektronik325 For This Useful Post:
    pawl (28th January, 2022)
