Results 1 to 4 of 4
    Feb 2017
    Default Renault Master 3 2014
    someone have an electrical diagram for master 3 2014, m9t engine?
    i have a problem with my fuel pump, i can't find the relay for the pump. i put an +12v to fix it temporary but i get an error on dashboard.
    if someone know where the brown cable go... thanks...
    Sep 2013
    garage
    post engine code and kw for more diagram
  3. The Following 3 Users Say Thank You to Mr BLACK For This Useful Post:
    Col19 (12th November, 2023), costimmc (29th January, 2025), Kanni2004 (28th January, 2022)
    Feb 2017
    Thanks for your answer, i will take a look but i find a solution.
    fuel pump was replaced and connector too (probably burn before)
    i test the upc(relay look like to be there) on an another master 3 it was working.
    i put a valve on fuel arival and the fuel don't go back, off error on ecu and make a new +12v apc with a fuse.
    the valve was necessary because the car start randomly after 1-2 start.
    now it's ok.
    Jan 2025
    Hi, i need wiring diagrams. My rear fog lights doesnt work. can you send me related wiring diagrams? it is renault master 3 (van, year 2015) m9t700 engine
