Results 1 to 15 of 28
    Question 2015 Vw golf 7 dash clone??
    Hey guys, curious if there is any tool that can clone dash in 2015 vw golf 7 part number 5G1920856. Original cluster is damaged turns off after a few minutes ,car starts and runs fine however dash dies shortly after.
    Oct 2014
    Netherlands
    If both orig and donor cluster are the same you should be able to read eeprom by OBD and write it to donor, which should be enough.
    You need proper tools for that though, and getting access to a cluster does require a valid transponder!
    Quote Originally Posted by H2Deetoo View Post
    You think writing original eeprom to donor dash is enough??
    Jan 2019
    United Kingdom
    Can you explain how you can write eeprom to another vag cluster without having security access as the key does not match the cluster, Do you know what your talking about
    Jan 2019
    United Kingdom
    Oct 2014
    Netherlands
    You need a proper tool which supports mqb clusters and allows you to read eeprom by OBD (tool like vvdi or avdi etc).
    The eeprom data you read is in plain format, and you can write it to donor cluster.
    And I already told here that you do need to have a valid transponder to get access to the donor cluster!
    So yes I do no know what I'm talking about. Read carefully my posts before stating things!
  7. The Following User Says Thank You to H2Deetoo For This Useful Post:
    AudiS4 (5th February, 2022)
    Oct 2020
    Bulgaria
    So these clusters are not crypto protected?
    Oct 2014
    Netherlands
    Crypto protected?
    When reading eeprom from MQB clusters with a proper tool it will provide eeprom data in plain format.
    I can't be much clearer then this...
  10. The Following User Says Thank You to H2Deetoo For This Useful Post:
  11. #9
    Oct 2020
    Bulgaria
    this is confusing, you mean write full eeprom content or immo data to new cluster? Do you really think you can write full eeprom to different cluster even with same part number im "plain format" and that will be encrypted correctly?
  12. #10
    Oct 2014
    Netherlands
    MQB clusters are a little different compared to PQ.
    The immo data is stored in plain format in the internal dataflash of the NEC cpu.
    So if you have a tool which can read MQB eeprom(=dataflash) by OBD, then you have all needed info (MAC,PC and TP CS) in plain format.
    You can write this data back (for sure partially) to a donor cluster (if you have valid transponder for it) and that's enough for the donor cluster to recognize and accept the original transponder, and the rest of needed data will be read from that tp.
    Rgs H2Deetoo
  13. The Following 3 Users Say Thank You to H2Deetoo For This Useful Post:
    Domi (5th February, 2022), evgeny87 (4th February, 2022), m_yura (5th February, 2024)
  14. #11
    Oct 2020
    Bulgaria
    Usefull info, thanks for that
  15. #12
    Jan 2019
    United Kingdom
    Anyone ever seen a cluster for sale with a working key? Either full ecu kit or just speedo so this in theory may be correct but in reality you will only buy a used speedo without key (no security access)
    Odis online is the correct way
  16. #13
    Oct 2014
    Netherlands
    I agree it's hard to find a used cluster+key, but I have obtained some so its not impossible
    And yes ODIS online is also a good solution.
    But I simply answered the TS question .. yes it's possible.
  17. #14
    Nov 2018
    P L
    Odis Online impossible. from last year Vag concern blocked the adaptation of used modules in which Immo and keys are stored
  18. #15
    Oct 2014
    Netherlands
    Also true indeed
