Results 1 to 11 of 11
    Default ccam 2.1.3 download
    got pli jade image on dreambox, the problem is when trying to download latest menu via software management im getting message saying no internet connection or server is down any ideas, have set my dreambox ip to 192.168.1.101 and my router ip as 192.168.1.100 when i connect to dreambox with flash fxp using these ips it connects no problem
    GastonJ's Avatar
    Have you got the DNS server information set up correctly? If you can ping your router from a telnet session, then try
    traceroute _www.yahoo.com
    remove the '_' form in front of www btw
    It will probably come back with unknown. Means your DNS servers aren't set.
    HTH
    mate havnt got a clue what u mean just started with this today what do u need to do to set up dns server
    GastonJ's Avatar
    I see. Ok well you have obviously been through the network confiiguration.
    Setup->System->Network Setting->DNS Settings
    The DNS information in there should be the same as the DNS settings on your computer.
    May also need to set your router/default gateway in network setup as well.
    HTH
    if i click on internet protocol tcp/ip then properties obtain ip adress automatically is highlighted and obtain dns server automatically is highlighted and my local area connection is disabled what info goes where sorry to be a pain been stuck on this all day
    GastonJ's Avatar
    Quote Originally Posted by jj1970 View Post
    Don't worry everyone starts somewhere. Enable the Local Area Network Connection, and save the changes, then retry. If you're using DHCP then then everything including DNS and router etc is taken care of.
    Cheers
    i have my local area connection enabled now showing a cable is unplugged and my wireless adapter enabled both tcp/ip properties are highlighted obtain ip address and dns server automatically what adapter should i put the info from the box on
    GastonJ's Avatar
    I would have been more inclined to use the wired LAN connection, rather than the wireless. I've not got wireless so don't know anything about it tbh. If you had a cable into your LAN, with DHCP set it should just pick IP, router and DNS settings from that.
    Sorry I can't help on the wireless.
    maybe i have set up wrong i have modem connected via ethernet to wan in the router and dreambox to port in router then i try to download new menu on my box from menu is this not the correct way
    GastonJ's Avatar
    No that sounds right, although you have wireless on it and no LAN cable., from all you've said.
    What you could do is download the ipk file for cccam. FTP it up to the /tmp directory on your DM, then use the file browser on the DM to install it from the /tmp directory.
    Cheers
    which cccam2.1.3 file can i ftp directly to tmp on the dreambox to get me past this . tried to ftp the ccam files i have but didnt do anything. the files i have were 7 individual files in the one cccam 2.1.3 folder they are as follows cccam.armeb-cccan.cfg-cccam.ppc-cccam1.1.3-cccam.armeb.eabi-cccam.mispel and changelog. all files ftp over no problem but dont think they are the right files thanks
