Results 1 to 7 of 7
    Dec 2018
    Latvia
    Default Audi TT 2.0T Bosch MED9.1 Immo off
    Hello can some one help with immo off for Bosch MED9.1 with numbers:
    Bosch 0261S02519
    VAG 8J0907115N
    Problem is that some one ~~~~ed ecu, there is no K-Line connection on ecu, wires good, ecu also do signals but no diag, after upload some another ecu back up, diag working immo on, VAG Geko account won't wanna adapt immo, to dashboard, solutions with FVDI don't work, Bosch MED9.1 eeprom editor also don't work, so i'm little stuck, also can't update ecu with Odis Engineering because no diag with ecu, so maybe know some other solutions for this situation? PLEASE NEED REALLY HELP!!!
    IMM0killer's Avatar
    May 2019
    Sometimes in eeprom , Sometimes in flash
    Dec 2018
    Latvia
    Quote Originally Posted by IMM0killer View Post
    press thanks and give rep
    Thnx will try tommorow, did i need use EEPROM, our eeprom and flash?
    Jan 2022
    9.1 eprom and flash
    Jan 2020
    I have this audi TT that when it starts after a few seconds it turns off again as if it had immo problems,
    I have no faults in the ecu
    I have tried immo off but it does the same thing
    Jan 2020
    Is possible corrupt file ?
    Jan 2020
    Need cs pin ect for start ? or run immo off no need cs pin ect ?
