Results 1 to 8 of 8
    Jan 2011
    Default A6 C6 REPLACEMENT DASH
    hello, it is possible to replace the instrument cluster without online? dash is virgin.
    Oct 2020
    Bulgaria
    4F is older generation 2 CP i think AVDI/FVDI can do this job. but if you remove CP with abrites - if necessary again next time - will be problem.
    Jan 2011
    Quote Originally Posted by evgeny87 View Post
    abrites did a virgin set of indicators and then filed, after the file from the gateway also filed
    Nov 2018
    P L
    what will be the problem ????? I do it very often and don't run into any problems.
    Nov 2018
    P L
    Virgin cluster, AVDI, file from Gateway and CP done. cluster unlocked, added to the car, fully functional. for A6 C7 we also do CP without Online.
    Oct 2020
    Bulgaria
    Quote Originally Posted by yarowsc View Post
    Dont know exactly, maybee abrites wite "something" in flash.
    So if is necessary again on this module, not successful.
    Jan 2011
    i have read file from gateway, i download abrites and it's bad
    Nov 2018
    P L
    I do such modifications very often, last yesterday, A6 C6 2007year, change cluster on lift ... 933Q. as always, everything ok. AVDI org. I have never encountered the problem of replacing a cluster in an A6 C6 using AVDI.
