    Feb 2022
    Default VCDS 21.9 and VCDS_Kolimer_Loader_9.2 not working
    Hi there, i hope im in the right place, if no, please let me know, im a new guy here.
    So on my laptop witch i am disconnected from the web i installed the VCDS 21.9 then i installed the Kolimer loader 9.2, it created a new icon on my desktop named " VCDS Loader " so my old VCDS exe file was replaced... teoreticaly it was installed properly.. After i opened the VCDS loader, i was going to do a test so i can save it and make a diag on my car.
    After making a test the following apears :
    Port Status : ok
    interface : not found
    im disconnected from the web on that pc, i installed the Kolimer Loader as i should, my drivers on the cable are installed ( i can work with vcds lite 1.3 with any problem) what might be the problem ? i uninstalled the old VCDS app, and reinstaled, didnt help, do i need to uninstal also the Lite version ? i have an blue cable KKL VAG-COM for 409.1, witch did work with the vcds lite free version downloaded from their site, i am asuming it might be working with VCDS 21.9 too
    thanks !
    Dec 2014
    PL
    You need a HEX-CAN interface with an Atmega 162 or HEX V2 STM 405 chip.
    Vag KKL interface does not work with VCDS 21.9.0 EN or other software.
    Look here:
    https://www.digital-kaos.co.uk/forum...light=vag+vcds
  3. The Following User Says Thank You to Mario6 For This Useful Post:
    Tnick (19th February, 2022)
    Feb 2022
    The KKL cable works fine with the VCDS Lite version, but i only have the free version downloaded from rosstech , i downloaded some drivers and isntalled it, after i installed them, the Lite version works fine with KKL cable, but not the VCDS 21.9,
    can u please tell my what application will work and can pull out error codes with the KKL cable ?
    im pretty new to these kind off apps, i own an audi a6 c5 year 2001 so i did not need the newest app, just a stable app which will pull all the codes of my audi, will you be kind to help me out ?
    Dec 2014
    PL
    Quote Originally Posted by Tnick View Post
    Read post #11
  6. The Following User Says Thank You to Mario6 For This Useful Post:
    Feb 2022
    134072453.jpg hi there, im wondering if this cable is good enough / will it work with VCDS 21.9 ? i found it pretty cheap, guy is selling for 20 euros, he told me he did not need it anymore, because he has a new car
    Thanks !
  8. #6
    Feb 2018
    Yes, he is good.
  9. The Following User Says Thank You to western6089 For This Useful Post:
    Tnick (21st February, 2022)
