Results 1 to 7 of 7
    Apr 2019
    London, UK
    Default 2.0tfsi BWA add 3 bar map sensor
    Hello
    I need a 3 bar map sensor added to this file if possible.
    The current map sensor is 2bar
    Audi A3 2.0 tfsi dsg 2006 Bwa engine
    ECUBosch MED9.1
    ECU
    Bosch MED9.1
  2. The Following User Says Thank You to alextinou For This Useful Post:
    mk5gt (31st March, 2022)
  3. #2
    Nov 2021
    Germany
    do you have the HW and SW number ??
    Nov 2021
    Germany
    Here try this
    Apr 2019
    London, UK
    Hi friend
    8P0907115K 0040 0261S02341_386817 2.0TFSI
    Apr 2019
    London, UK
    Using MPPS tool
    May 2022
    hello, I need a file with map 3 bar and more pressure from the rail line, maybe put a 200bar jetta sensor, from the same audi bwa engine, would anyone be able to? I'm having trouble doing this conversion
    May 2022
    Default MAP 3 BAR RAIL 200 BAR
    my audi has intake, flap delete, downpipe, pcv delete, k04, autotech HPFP, walbro 450, rs4 restrictor, I'm going to put forged piston and connecting rod
    8P0907115K
    0261S02341
