Results 1 to 14 of 14
Thread: pcr 2.1 clone
    Default pcr 2.1 clone
    hello
    i have simos pcr 2.1 skoda
    both ecu have cs pin mac available i have
    is it possible to tranfer direct
    orgnal car = cs - 05 CE 75 2A 0F B2 00 PIN - 27962 mac - A2 98 A2 98
    DONAR CAR = CS - D3 CE E2 CB 21 00 PIN - 8803 MAC - C7 24 C7 24
    below attach both file full back up both ecu unlocked with flex obd
    topclef's Avatar
    Sorry , i made a mistake try this one
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  3. The Following User Says Thank You to topclef For This Useful Post:
    maruti (1st March, 2022)
    thanks for help report will take time bcoz car away
    hello
    not working dear
    safe on display - control module incorrect coding
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by maruti View Post
    hello
    hello
    not working dear
    Because dear ​Mr. maruti , information from both ecu MAC is wrong then CS not correct !
    And I tell more .....both ecu have different power class !
    There right option about both ecu security information Mr.
    maruti !
    Donor ecu .......
    Power Class: 3A
    CS: D3 CE E2 2C CB 21
    MAC: C7 24 FB 41
    PIN: 08803
    Original ecu..........
    Power Class: A2
    CS: 05 CE 75 2A 0F B2
    MAC: A2 98 01 FE
    PIN: 27962
  7. The Following User Says Thank You to brend For This Useful Post:
    topclef (6th March, 2022)
  8. #6
    hello
    i extract with avdi
    is that i am doing something wrong ?
    unlock with x17 vai obd
    but if i am do wrong please tell me
  9. #7
    Oct 2014
    Netherlands
    Hi, the problem is that the donor ecu is for brand SKODA, while your orig ecu is for brand VW.
    This will cause immo problem.
    Attached is flash+eeprom for your donor ecu.
    It has your immo copied and brand set to VW.
    Please try and report!
    Regards,
    H2Deetoo
  10. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    lupu_sandu (7th March, 2022), maruti (7th March, 2022)
  11. #8
    brend's Avatar
    Oct 2015
    Same where
    hello
    i extract with avdi
    Nothing .
    Wrong security information = no resault's !...........That's it !
  12. #9
    thanks for everone help but at last i chnage mcu with my bga rework station
    bcoz here in india customer buy ecu from scrap market
    4D457ABB-BD0D-470B-A196-4D3214EF4587.jpg203F82B9-C7C8-48D9-90C9-1C6D706F9C60.jpg76226E53-E57C-4737-A6BD-C09AA23933F2.jpgA690DBA9-64BE-419B-AAE5-3583067BBD93.jpg
  13. #10
    Oct 2014
    Netherlands
    @maruti my clone attempt was not working?
    It would be interesting to know what the exact DTC error you had?
  14. #11
    Jun 2013
    EU
    Quote Originally Posted by H2Deetoo View Post
    He did it the hard way mate, surely not even tested your file before, rush is bad travel mate.
  15. The Following User Says Thank You to morgano For This Useful Post:
    brend (11th March, 2022)
  16. #12
    brend's Avatar
    Oct 2015
    Same where
    Absolutely agree with morgano .....
    For work with Pcr 2.1 need good experience .
    Without .......only solder and desolder and play forever ....
  17. The Following User Says Thank You to brend For This Useful Post:
    maruti (12th March, 2022)
  18. #13
    i know its hard & need much knowledge & i have flex x17 also but some time that job also so much time taken
    agian thanks all of for help me for clone
    but here in india may bi usd 100 kit availabe like ECU + CLUSTER + KEY at scrap market
    so i must do work otherwise job left
  19. #14
    May 2020
    tot557545@gmail.com
    maruti
    Hello all Help you friend , please press thnx+Reputation button
    ori ecu working data
    VIN: MEXF17600HT136525
    CS: 05CE752A0FB200
    MAC: 01FEA298
    PIN: 27962
    POWERCLASS: A2
