    Aug 2015
    Austria
    Default VW Crafter EDC16CP34 immo off
    someone lost me ecu, need to immo off on this new ecu, can someone help?
    Software Nr.: 1037503936
    Software Upgrade Nr.: 074906032AT 5175
    Chassis Number: WV1ZZZ2EZ76013377
    IMM0killer's Avatar
    May 2019
    Sometimes in eeprom , Sometimes in flash
    here
    press thanks and give rep
  3. The Following User Says Thank You to IMM0killer For This Useful Post:
    xxxm3 (2nd March, 2022)
    Aug 2015
    Austria
    Thanks, but I made this also with immotool but not working, this 4 bits I guess is not enough. see other files and there are many more changes done
    Nov 2019
    this is the correct way for immo off and it is enough
  6. The Following User Says Thank You to jahjadorambari For This Useful Post:
    IMM0killer (2nd March, 2022)
    IMM0killer's Avatar
    May 2019
    this is not any tool mate
    i made my own solution for med edc 17 and my own checksum correction
    may be there are another issue in the car
  8. #6
    Aug 2015
    Austria
    ok thanks! so looking immotool1.5 isn't so bad, cause made the same changes. have to look again, whats the problem on the car
