Results 1 to 7 of 7
    Default Fiat Stilo vibration
    Fiat Stilo 2001
    1.9 JTD 8V
    I have a problem with the gearbox, appeared some oil in the clutch, then fixed the problem the car make vibration betwen 1500 and 2000 rpm, the flywheel and the clutch are new spare parts.
    i tried several mechanics and i can find some who fixed the problem.
    Appreciate some help please.
    Netherlands
    Is the flywheel new? I mean from a dealer. Usually this is the problem with these cars.
    Yes, the flywheel is new, valeo spare part original acessory.
    already been place a new transmission in the left side but the vibration persists, i can not understand wich generates this vibration, its strange.
    Member Donut Boi's Avatar
    Does it do it when driving or revving the car when standing still? or both?
    Have you checked the fly wheel is balanced?
    when was the car last serviced?
    yellowstilo's Avatar
    i know there were problems with certain engine suspensions (rubber dampers) which generate vibration problems because the rubber got very hard after a few years.
    There was a replacement part made for this issue.
    I think your dealer can tell you if this applies to your car.
    Only generate vibration when the car is driving, mainly 4th and 5th gear and between 1500 rpm and 2000 rpm capriciously when pull at maximum, however if progressive not feel vibration.
    The car has 197852KM and its the first time i have a big problem.
    The fly wheel is new spare part, and it was verified two times
    Time needed for service 2489km.
    The oil came from one cranckshaft bolt and infectd the clutch causing slippage when accelerate
    Ashraf6119's Avatar
    UK
    Check the Dry Shaft's it could be one of the inner CV joint ball bearing dropped out while putting in back and causing this problem.
    Best way is to remove both shaft out again check and refit it back.
    Hope This Helps
    Ash
