    Jul 2013
    romania
    Default dtc off vw passat edc17cp14 2.0 103 kw
    hy guys,need to help me to make dtc off on vw passat from 2010 ecu is bosch edc17cp14,103kw,2.0 diesel
    the error is P2015 and i whant to make off this error ..i will atach files from ecu read with ktag in bdm...
    so the error is P2015-INTAKE MANIFOLD RUNNER POSITION SENSOR/SWICH CIRCUIT
    Dec 2021
    Bosnia and Herzegovina
    Try this and let me know if it worked.
  3. The Following User Says Thank You to mire922 For This Useful Post:
    cutiutza (9th March, 2022)
    Jul 2013
    romania
    DO YOU MAKE DTC OFF OF MY FILLE? ONLY P2015?
    Dec 2021
    Yes i turned P2015 OFF
  6. The Following User Says Thank You to mire922 For This Useful Post:
    yahiadiag's Avatar
    Feb 2019
    hi
    here is dtc off
  8. #6
    Jul 2013
    romania
    mire,your file is ok..thanks
    yahiadiag..i dont ceck your fille ,but thanks alot
  9. The Following User Says Thank You to cutiutza For This Useful Post:
    mire922 (9th March, 2022)
