Results 1 to 14 of 14
    Mar 2020
    Default Help with bosch m3.8.3 AGU and Cruise Control
    hello, i have a 1999 1.8T AGU Golf with factory fitted Cruise control.
    the original ecu is damaged and it was a 06A906018 BB so i bought a 06A906018 R,
    i did immo off reading and editing the B58258 dump, the car works but i don't have the cruise feature anymore and i cant set the throttle in vcds, it gives me error
    how can i enable it? and which solution can i use for reading the ecu? galletto? kess?
    i read somewere that's not easy to read and write this kind of ecu
    alonedark's Avatar
    Feb 2017
    if easy put original files and change A0 by 50 in eprom dump,if better for help you put ecun number , years ........
    and when you learn everything from these ecus that you are going to do with electric cars
    alonedark's Avatar
    Feb 2017
    if you want the mod file upload ori and mod i do it for you
  4. The Following User Says Thank You to alonedark For This Useful Post:
    DjDecibel (14th September, 2022)
    alonedark's Avatar
    Feb 2017
    dont forget check sum in eprom file
    Mar 2020
    Quote Originally Posted by alonedark View Post
    which tool will work with this kind of ecu?
    can i read it thru obd port?
    Baddog84's Avatar
    Sep 2012
    Germany
    Quote Originally Posted by DjDecibel View Post
    eprom programmer need
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
    Mar 2020
    Sorry for the late reply but my programmer was broken, so finally i got the new one!
    the codes on ecu are:
    06A906018 R
    Benzin D06
    bosch 0261204673
    01.03.99 26SA5648
    and the attached file is the ecu dump
    it should be SW 358109
    can you mod it reenabling the cruise? or i should re-flash it with a BB version?
    Aug 2015
    06A906018 R
    Benzin D06
    bosch 0261204673
    01.03.99 26SA5648
    You can reflash it, but eep too!
    [hr]
    THANKS + REP if I help you
  10. #9
    Mar 2020
    Quote Originally Posted by Pacsat View Post
    so i should reflash both eeprom and flash? i don't have both, i just found a ori BB flash file on another thread
    and i don't have the damaged ecu anymore
  11. #10
    Aug 2015
    Try this eeprom
    [hr]
  12. #11
    alonedark's Avatar
    Feb 2017
    you have here put inmo off in your original file
  13. The Following User Says Thank You to alonedark For This Useful Post:
    geralsony (8th November, 2024)
  14. #12
    Mar 2020
    ok, i flashed the BB files in eeprom and rom but now the car don't start and i have this error in vcds:
    01314 - Engine Control Modole
    37-00 Faulty
    i flashed back the R files and the car start again and no error in the ecu.. so i think that r and bb are different
  15. #13
    Aug 2015
    For sure BB and R are different
    I think you have a checksum problem...
    Try this eeprom.
    But you must match immo.
    [hr]
  16. #14
    Mar 2020
    Try this eeprom.
    i checked the bb ori i found with winols, and they looks broken or with checksum problems
    do you also have the flash ori that matches the eeprom you posted?
