Hi friends. I have next problem. Front wiper, only on driver side work all the time, on passenger side not work. On driver side work in slow mode and not in full deviation. And work after ignition off for one time. I guess wipers work in some protection mode, because of absence of communication with vehicle. When i make full diagnosis with OEM diag i have no communication with Trailer module, Auxiliary heater module and with Front right and front left wiper module (or master and slave, i cant remember names). All fuses in passenger compartment are okay, on driver side fuses location i do not have +12v at any on fuses, most of them are 3A, 5A and some of 10A (i did not pull them out). Under hood all fuses are okay. I do not have schematic diagram for this vehicle. I am interested, did some of this 4 modules have 2 x 2 CAN lines, like CAN H CAN L in and out and that module is in problem and because of him i do not have pass trough communication with other modules. And if anyone can tell where is Auxiliary heater module is located, and where is located Trailer module.
And the last, to not forget, i have complain in BSI and one more module on LIN line problem.
Or someone have the same propblem.
Thank you
