Bcm2 8K0907064Cf damaged. Please info for repair software. D-Flash or P-Flash
Maybe if you post dumps of PFlash and DFlash you could get some help, only with a picture is a bit difficult.
ECU-IMMO-Dash-Airbag Solutions
VAG Immo Transfer Solutions
FRF/SGO/ODX/SOX <--> BIN Conversion
Thank you Antonnio266 . There files
your bcm need repair,is corrupted
What problem do you have? Car doesn't start?
Do you have any DTC's?
Thank you for answer emanuel2010
That's how everything points to it. That's why I need to read a working P-Flash
nothing lights up. Only lights can be turned on. does not want to connect diagnistically with any module. NI grabs the key and does not turn on the clocks. The engine does not start. After the analysis, I came to the conclusion that the reason for the lack of diagnosis is the lack of control by BCM2 of the accessory relay. Making a armature on this relay allows you to perform diagnostics. At least other modules are reporting but there is a lack of communication with BCM2 in errors. If you enter BCM2 directly not through a scan, it connects but only shows identifications. So, from my findings, there is a corrupted software in BCM2. Other modules also report an incorrect VIN in BCM2
The read BCM2 Abrit
Gateway dtc code 01330 (J393) J519 code dtc 01330 (J393)
Antonio266 any conclusions ?
In my opinion damaged D-Flash. Any sugestions for repair ?
Thank you all for your help.
I solved the problem by uploading a working D-Flash and re-training BCM2 using the abrites device.
darknezz19 (27th March, 2022), fedji23 (27th March, 2022), fuzz1 (19th June, 2022)
Bună. Mașina mea a fost inundată în Germania în septembrie 2021 și acum încerc să o repar(clonez bcm2, elv, blocarea contactului, bcm1, dar nu pot pune aprinderea și clusterul afișajului spune "blocarea aprinderii defectă". Trebuie să repar eeprom(i) cred) sau nec sau altceva.Nec
70F3381M2(A1)
Eeprom 95320
DTC în modulul 05 este 01330
DTC în modulul 46 este 00003....modulul de control defect
Atach citire originală de la bcm2 inundat...
vă rog să mă ajutați pentru că încerc toate soluțiile posibile și nimic nu funcționează,
toate cablările sunt verificate de multe ori,
thx pentru toți și apreciez lucrările dumneavoastră
Please use only English
hi. my car was flooded in Germany in september 2021 and now i try to repair it( i clone bcm2, elv, ignition lock, bcm1 but i cant put on ingnition and display cluster say " ignition lock defective". i need to repair eeprom(i think) or nec or something else.
Nec 70F3381M2(A1)
Eeprom 95320
DTC in 05 module is 01330
DTC in 46 module is 00003....control module defective
i atach original read from flooded bcm2...
please help me because i try all possible solution and nothing work
all wiring is verified for many times
thx for all and i apreciate your works
