Results 1 to 15 of 28
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Default Read and Write R7F7010713 with VVDI
    hi, I followed information to read VW21 golf R7F7010713 con VVDI Prog.
    VVDI provide schematic, I have read Dflash and Cflash.
    cleared in Dflash , but when I go to write, it tells me that this function is not available?! possible ?
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    superjet's Avatar
    Aug 2018
    if you write cause lost module defetive,lost communication.......
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    mmmmm.... cflash erase e write ok ..... boot erase e write ok .... dflash read ...erase ok ... no write !
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by centrohifi View Post
    all file write ok but cause lost module defetive,lost communication.
    this is my mean..........
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    ... Use Upa-S written processor, no problem.
    Then I connected VVDI read and everything ok .. edited file.
    With VVDI to change you have to use the Boot function.
    Boot is the same as dflash
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    tomorrow try on T-Roc VW
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    I confirm ... to modify crash you have to read "Boot" ... modify, and write clear "boot"
  8. The Following User Says Thank You to centrohifi For This Useful Post:
    tarasad (24th November, 2022)
    VW21_ R7f7010713. I've written a lot using vvdiprog, and there's no problem
    Having written dflash will make the module not communicate, which can be solved perfectly.
    Similarly, some GM Chevrolet Opel modules, r7f7010623, have written dflash, and the module will not communicate, which can also be solved perfectly
  10. The Following 3 Users Say Thank You to bolonc For This Useful Post:
    centrohifi (14th April, 2022), junmab (24th March, 2022), nikolina (26th March, 2025)
  11. #9
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by bolonc View Post
    did you have skyper or other contact?
  12. #10
    You need to fix this module, PM me
  13. #11
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    I still don't have, car here to install ECU. like reading post, it is likely not communicating. contact you when that's all, and then look for a solution.
    @superjet my contact skype: xxxxxxxxxxxxx
    @bolonc send you PM
    ThK
    Last edited by gmb45; 25th March, 2022 at 09:38 AM. Reason: read the rules again mate !!!
  14. #12
    Quote Originally Posted by superjet View Post
    NO skyper......
  15. #13
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    I can have information, to wake up this ecu.
    I've read everywhere what the problem is in writing dflash.
    Now I have two locked ECUs
  16. #14
    superjet's Avatar
    Aug 2018
    [QUOTE=centrohifi;4324950]I can have information, to wake up this ecu.
    Did you sloved?
  17. The Following User Says Thank You to superjet For This Useful Post:
    centrohifi (15th April, 2022)
  18. #15
    fuzz1's Avatar
    Jul 2019
    How do you solve this problem of no com after writing d flash?
  19. The Following User Says Thank You to fuzz1 For This Useful Post:
