Results 1 to 15 of 20
    Post op com 90820 activation code
    im trying to find out how to get activation code from winhex
    odyseus7's Avatar
    GREECE
    try this work
  3. The Following User Says Thank You to odyseus7 For This Useful Post:
    ebrar46 (6th August, 2018)
    thanks ...
    Default hy
    Quote Originally Posted by odyseus7 View Post
    try this work
    can u dld your file?
    i'm trying to find the activation code for op-com too, can't find the 8-3 serial number or the 8-8, help please
    DK Veteran sl4ck's Avatar
    Default activation code
    hi
    I cannot get a code for my opcom.I unfortunately upgraded the thing before activation any ideas?
    cannot go into the rapidshare link as you only had 10 goes and no more.
    I cannot get the winhex suppled by the ebayr to load.
    thankyou
    Here winhex. You have to use the descriptions of how to use, but you can find the activation code, just need to type the serial and then F3 to manually search the bottom. I found after 1 hour
  10. #9
    Default winhex
    Thank you for the download.
    This does the same thing on two differrent computers.
    fails to load and says
    c\documentsandsettings\general\localsettings\temp\ bz_temp\winhex154language dat
    fails to load
    any ideas?
  11. #10
    You don`t need install. Only unpack and run winhex.exe. Not registered but by me work
  12. #11
    Member drdre20013's Avatar
  13. #12
    Default opcom
    Thanks for the reply.This will run but refuses to recognise the interface.
    When going to diagnostics it says acannot load the ecu list.
    I think I made an error when first loading the soft ware the old software would not load so I tried the after the firmware update.Hexwil will not load or run.When opening the update software the computer finds the interface and the tx light goes on.I cannot get the activation code as hexwin will not load or run.
    have I cocked it up?
  14. #13
    should also add the opcom version o9082b
  15. #14
    and I also forgot winhex will not run either.
  16. #15
    Thanks for this
