Results 1 to 8 of 8
    Mar 2022
    us
    Default 2000 audi a8 immo off
    I have 2000 audi a8 did read with mpps v18 can someone immo off for me.
    Feb 2018
    Test and report.
    kiszka's Avatar
    Quote Originally Posted by SebaGTC View Post
    Test and report.
    this is not an eeprom but a flash
    Mar 2022
    us
    ok i wrote file and now car will not start cannot see ecu i have ktag and mppvs with cables can you help me with a way to fix please
    kiszka's Avatar
    Quote Originally Posted by Phnman390 View Post
    earlier, I wrote the post clearly, the guest packed a solution with eeprom to flash and did not inform that it would be useful to count the CRC
    you will save it from MPPS as you run bootloader
    Mar 2022
    us
    i messed up and flashed it normally via obd can i bench flash with mpps the file? and what would be the pinout?
    kiszka's Avatar
    you searched on google, you can easily find an ECU for it
    Mar 2022
    us
    i have ktag and mpps i flashed the file that i download directy to ecu via obd is there a way to fix with ktag or mpps out of vehicle?
