Results 1 to 2 of 2
    Mar 2022
    australia
    Default need help 2014 Mitsubishi mirage ECU mapping
    Hello all, i've scoured the internet in order to find anything related to the development of tuning support for the latest generation of mirages, unfortunately there's essentially no info regarding the rom definitions, it's no surprise.
    I've been attempting to pull some maps i've found in winols, there's no damos for this year model, so trying to make sense of the tables i have found is incredibly difficult, if anyone has the xml for this ecu in order to tune it with ecuflash, there's a bunch of people who would appreciate it very much if it was shared.
    year<2014>
    manufacturer<Mitsubishi>
    model<Mirage>
    engine<3a92> (1.2L 3cyl)
    transmission<5MT>
    ecu HW 1860C140
    ecu SW 1860C14001
    ecu SW version 103006
    ecu CAL-ID 1860C14001012014 mitsubishi mirage.zip2014 mitsubishi mirage.zip
    ecu CVN F7E145C8
    ecu supplier confirm = 85
    Thanks for reading through, hope you all have a great day!
    yamomoto's Avatar
    Oct 2015
    everything is simple there as an agricultural implement - a rake.
    I can write a detailed xml-file for ~200-250 parameters (maybe even more) in 4-5 days.
    Plus full periphery mask and DTC mask.
    But it's not free.
    For example in your dump :
    加速時ショック対策 判定 下限
    lower limit RPM for hard acceleration (XADSKNEH) 1500 min-1
    加速時ショック対策 判定 上限
    upper limit RPM for hard acceleration (XADSKNEL) 3500 min-1
    加速時ショック対策 判定車速
    min allowed vehicle speed for hard acceleration (XADSKVS) 10 km/h
    加速時ショック対策 判定水温
    min permitted coolant temperature for hard acceleration (XADSKWT) +215 deg.C
    発進時 カット 判定車速 下側
    lower hysteresis for limiting operation A/C ON by vehicle speed (XACSTOFVSL) 9 km/h
    発進時 カット 判定車速 上側
    upper hysteresis for limiting operation A/C ON by vehicle speed (XACSTOFVSH) 10 km/h
    or:
    最高速カット 判定車速 復帰
    limit vehicle speed fuel supply restrictions (XVSFCU) 200 km/h
    最高速カット 判定車速 解除
    limit vehicle speed fuel permits (XVSFCL) 196 km/h
    BR.
