Results 1 to 5 of 5
    autobo's Avatar
    May 2014
    Bulgaria
    Default Nissan Micra K14 crash
    Hi friends.
    I need help to clear crash on this nissan micra k14 98820-5FB0C_R7F701018.
    I paid for two different dumps,but without luck.With first one SRS light go out, but I have fault code B1422-side collision detection.
    With second dump no communication with SRS module.
    Attached original dump from car.
    Thanks in advance.
    Dec 2010
    Here is your file cleared
  3. The Following User Says Thank You to ELETTRA64 For This Useful Post:
    autobo (6th April, 2022)
    autobo's Avatar
    May 2014
    Bulgaria
    Thank you friend,but with this dump no communication with SRS module.
    Dec 2020
    If you want a sure solution, use Carprogonline.com solution, it works tested.
    ECU-IMMO-Dash-Airbag Solutions
    VAG Immo Transfer Solutions
    FRF/SGO/ODX/SOX <--> BIN Conversion
  6. The Following User Says Thank You to Antonio266 For This Useful Post:
    autobo (7th April, 2022)
  7. #5
    autobo's Avatar
    May 2014
    Bulgaria
    Problem solved with carprog online solution.
