Results 1 to 3 of 3
Thread: BMW E46 cluster
    nezocas's Avatar
    Dec 2015
    Portugal
    Default BMW E46 cluster
    How can we solve the PPPPPPP issue on this type of clusters???
    BMW E46..... 320D...... 150Hp...... with automatic gearbox
    Part number:
    Bosch 658
    0 263 639 003
    Hw: 21.0
    Code: 07H
    Diag: 54H
    Bus: 13H
    Best regards
    Nezocas
    X-Prog 5.60 / Upa-Usb 1.3 / CarProg 4.74 and 7.28 / MiniPro / Galletto 4 VD300 / Digiprog 3 / SVCI 2018 / Autel MP808 / Autocom 2020.23 / USBDM / Skyprog / RT809H / R270+ / Lexia PP2000 / VCDS / Op-com
    Jul 2016
    Cluster lost coding ,common issue on these models of Bmw . Easy fix with a $20 Pa soft 1.4 /bmw scanner or ncs expert ,just copy data from ews to kombi/ike and job done .
  3. The Following User Says Thank You to Etownbrawler For This Useful Post:
    nezocas (23rd April, 2022)
    nezocas's Avatar
    Dec 2015
    Portugal
    Quote Originally Posted by Etownbrawler View Post
    SOLVED,
    Used Abrites, no need to go to the special funtions at all, just go under cluster and click the reset, all working again.... under 5 seconds.
    Best regards
    Nezocas
  5. The Following User Says Thank You to nezocas For This Useful Post:
    dashradio (3rd May, 2022)
