Results 16 to 30 of 32
  1. #16
    Sep 2016
    Hitag2 smart keys from FCA are possible to reuse without virgin as far me is known. I doubt in Dodge will be different.
  2. #17
    Dec 2020
    The original Hitag2 keys that came with the vehicle cannot be reprogrammed once they are locked to the vehicle (RFHub). If I read them with the xp400 they even show status locked. For shits and giggles I tried to program a locked key and it wouldn’t program. Had to put a virgin file to the key and then it programmed up like nobodies business.
    Once you change out the RFHub you need to program up new keys (at least one) first. Then you do the RFHub replace, which marries the RFH to the BCM and the VIN from the BCM is getting copied to the RFH. Done.
    A new virgin RFH has a VIN 0000000000000 and a PIN of 0000. The newer Dodges come with the RFH VIN locked. It is not possible to learn a different VIN to them, unless maybe someone gets a hand on a virgin one and reads out the RFH and flashes them files directly to the used RFH. Kinda same idea I did with the original keys.
    Unfortunatly I don’t have a Xhorse programmer yet, only got the IM508s with a XP400 from Autel. Maybe in a year or so I can afford another programmer and I’ll try to read more modules and post them files.
    The RFH in the Autel diagnostics function is hidden where the radio is.
  3. #18
    Feb 2024
    Quote Originally Posted by alex_r_2001 View Post
    Io terminal does full read and write. IM still waiting on a virgin rf hub from dealer to read out and save ....
    Hey buddy did u ever get the new rfhub for virgin readout ?
  4. #19
    Feb 2024
    Quote Originally Posted by CasMo View Post
    Hey what’s going on so ur saying vehicles 22-23 Rfhub are locked and can’t rewrite vin ? If so there is no way around that ?
  5. #20
    Dec 2020
    Yes, Dodge locked the VIN in the RFHub in the latest model years and you just can't put a different VIN number to it (at least it is like that here in the North American market). Same like factory Hitag2 keyfobs. I suppose if one has a virgin RFH and make a virgin dump one could maybe flash the used RFH and get it going virgin again that way.
    Others changed the original VIN on the BCM, PCM etc to mach the one on the RFH. I just find that later idea gross and isn't a real fix.
  6. #21
    alex_r_2001's Avatar
    New Jersey ,, USA
    Quote Originally Posted by Freshfresh View Post
    2019 Dodge Charger Virgin RFhub pin code 0000
    Solidarity with Ukraine
  7. The Following 13 Users Say Thank You to alex_r_2001 For This Useful Post:
    CasMo (8th February, 2024), Faraday (15th February, 2024), Freezzby (2nd October, 2024), HDPTA (9th February, 2025), jman1530 (26th August, 2024), kajoka (18th August, 2024), qeso705 (9th February, 2024), rob h (7th February, 2024), shpuncik (3rd January, 2025), tzveti (5th February, 2025), vov4ik (31st January, 2025), wojtauek (3rd September, 2024), wuza (7th February, 2024)
  8. #22
    Dec 2020
    The chip on my RFH is different... XC2265N... and off course the XP400 can't read it.
  9. #23
    rob h's Avatar
    May 2011
    You could invest in a vvdiprog.
    If you order the exact partnumber rfhub, you could make a backup.
    And perhaps share your files, like other do.
  10. #24
    Dec 2020
    Quote Originally Posted by rob h View Post
    yep… unfortunately at the moment I can only do what the IM508s and the XP400 can do. I am not a stranger in electronics repair, just have a bit trouble on what programmer to use for whatever brand / module.
  11. #25
    Feb 2017
    Madrid Spain
    I have the same problem with vin 0000 unprogrammed key I try to read pin code with alfaobd and it gives me pin 00C6 but when trying to program it says incorrect pin code I tried to change vin in eeprom 95640 but also without success they have schemes to read flash and eeprom microprocessor? I don't see the connections in vvdi
  12. #26
    rob h's Avatar
    May 2011
    If you show us a picture, of the pcb.
    And what kind of mcu is in there?
    9S12XEQ384 ?
    What tool are you using to read the pincode? Besides Alfaobd,
    670102548 RFhub 2016 Maserati Levante M161
    What happened to the original rfhub?
    https://www.digital-kaos.co.uk/forum...keyless-module
  13. The Following User Says Thank You to rob h For This Useful Post:
    dashtool2016 (14th February, 2024)
  14. #27
    Dec 2020
    Quote Originally Posted by dashtool2016 View Post
    The 4 digit PIN on the RFHub is numeric only, no letters in there... At least I haven't seen any letters in the PIN yet. So 00C6 reading is garbage IMHO. Also this PIN is for the fobik only. BTW, the PIN can change from 0000 to whatever it used to be without loosing the programmed fobik.
    Try programming the fobik with PIN as 0000.
  15. The Following User Says Thank You to CasMo For This Useful Post:
  16. #28
    Feb 2017
    Madrid Spain
    it does not accept 0000 can someone tell me the pin of the dump
  17. #29
    Feb 2024
    IM able to change vin in rfhub if service needed hit me .. send me file with updated vin and i can get it done for you
  18. #30
    Oct 2022
    I found out Lickety Split can solved this issue! I used them on a swap for a SRT 2022 Charger and it was affordable that is there whatapp @ xxxxxxxxxxxxxx
