Results 1 to 8 of 8
    sdnatlst's Avatar
    Aug 2011
    England
    Default fiat panda 2004 - remote key learning
    hi all, i know years ago these were only do able with remote via TMPRO , is that still the case? nothing can precode and learn the key including remote functionality like autel or obdstar vvdi2 etc?
    is the eeprom readable via OBD?
    never bothered with one of these before.
    Tools owned -
    Dec 2020
    Only TMPro for Remote key precoding, with other Tools it won't work.
    Eeprom can be read by OBD no problems, I use AVDI for it, and TMPro recognizes the file correctly
    ECU-IMMO-Dash-Airbag Solutions
    VAG Immo Transfer Solutions
    FRF/SGO/ODX/SOX <--> BIN Conversion
    jodge's Avatar
    Mar 2017
    +1 miraclone
    castin's Avatar
    Oct 2015
    AVDI prepare this remote OK.
  5. The Following User Says Thank You to castin For This Useful Post:
    godfathertwo (27th June, 2022)
    Aug 2019
    Bucharest Romania
    Quote Originally Posted by castin View Post
    Which version of software? I have SVCI 2020 with Fiat software version 5.7.
    castin's Avatar
    Oct 2015
    Orginal avdi
    Dec 2020
    AVDI can't precode Remote for Fiat Panda 169, it can only precode the Transponder part, it obviuosly can prepare a virgin Remote Key but then when you program it the Car will only start, remote won't work.
    The only Tool capable of Remote precoding is TMPro2 with Fiat Panda BSI Siemens module.
  9. The Following User Says Thank You to Antonio266 For This Useful Post:
    andreia67 (27th June, 2022)
  10. #8
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by Antonio266 View Post
    nope, miraclone too
  11. The Following User Says Thank You to jodge For This Useful Post:
    musti418 (28th June, 2022)
