Results 1 to 14 of 14
    May 2022
    Venezuela
    Default help correct this angle sensor 4runner 89245-30110 eeprom s24cs0
    Hello, can you help me to clean the code of this steering wheel angle sensor 89245-30110 eeprom s24cs0
    superjet's Avatar
    Aug 2018
    your select chip is not adapt
  3. The Following User Says Thank You to superjet For This Useful Post:
    malaverjemm (24th May, 2022)
    May 2022
    Venezuela
    Default Thank you
    Quote Originally Posted by superjet View Post
    This one in particular cannot be modified?
    superjet's Avatar
    Aug 2018
    why you not select right chip to read it?
  6. The Following User Says Thank You to superjet For This Useful Post:
    May 2022
    Venezuela
    because I can't find a way to read it with the s24cs0 chip, it doesn't appear in the ch341 programmer
  8. #6
    fuzz1's Avatar
    Jul 2019
    Try to read as 24c02. What did you read it as?
  9. #7
    superjet's Avatar
    Aug 2018
    89245-30110 s24cs02
  10. #8
    May 2022
    Venezuela
    Quote Originally Posted by fuzz1 View Post
    i read it as 24c4096
  11. #9
    superjet's Avatar
    Aug 2018
  12. The Following User Says Thank You to superjet For This Useful Post:
  13. #10
    May 2022
    Venezuela
    I already read it as 24c02 before I didn't read it, it's from a sensor 89245-30110, can it be cleaned in this way?
  14. #11
    epd1221's Avatar
    Nov 2011
    usa
    heres repair report back
  15. The Following User Says Thank You to epd1221 For This Useful Post:
    malaverjemm (25th May, 2022)
  16. #12
    Feb 2019
    PL
    Test and report
  17. The Following User Says Thank You to tamaszek369 For This Useful Post:
  18. #13
    May 2022
    Venezuela
    I tried it but when I connect it does not delete the light, and the damaged file appears again.
  19. #14
    Feb 2019
    PL
    And do you see the rotation angle in the parameters?
    If it is more than 720 or 0 you have to correct to the apparent lower value accordingly and then calibrate
