Results 1 to 3 of 3
    May 2022
    Default Ktag external exception eefface error
    Hi guys
    I'm trying to get my VW touran 2.0 TDI back on the road.
    I have an Ecu fault , bought another (all the same numbers), bought a Ktag(7.020) and using ksuite supplied ( v2.25) Hoping to do the IMMO Off as i damged the origional PCB tring to take it apart Learnt from my mistake and sucessfully opened the other one without any carnage.
    ECU is an EDC17C46 i'm using Jtag/BDM interface with the 3 probes on the PC next to the tricore IC.
    tried some other versions , i'm runnning windows 7 32bit with internet on and express VPN
    Keep getting "external exception eefface error" when i select OK after the ecu selection page.
    any ideas ??????
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Check your connections...
    Post a clear photo of what you have connect...
    Jun 2013
    EU
    EEEFACE normally is problem accessing the SD card by the NXP processor.
  4. The Following User Says Thank You to morgano For This Useful Post:
    alirezatorkian (15th November, 2024)
