Results 1 to 15 of 19
Thread: Kuga non start
    Default Kuga non start
    2010 reg. 2.0 tdci. Not doing anything when pressing start button. Only faultcode is. B159a.60 ignition compare. Changed bcm and programmed 2 keys but sti the same. All fuses and relays ok. Remotes work opening the central locking. Can anyone help please
    fuzz1's Avatar
    Jul 2019
    When you say not doing anything? Means it does not say key not found? Maybe start button not working
    on ignition all light came as it should?
    especially ecu engine and spiral light
    When you press start button nothing happens. Sometimes says steering locked but steering lock is off
    May 2022
    Ukraine
    Is this a complaint or does everyone know from memory that the code = ignition switch compare failure ..
    Have you tried closing the main relay?
    Does the block see all limit switches and switches?
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by radiosolutions View Post
    I have same problem till 2 weeks ago.
    Cental looking work , lights are working but no ignition , no start .
    I put to { + } on the keyless fuse on BCM or GEM { fuse box } on the car and light on dash and clima working but the car not start.
    All this problem comme when i put other navigation with clima inside NX navi , the car have sony radio with clima doble down the radio .
    This upgrade cost me a lot , because i change the gem module and car still no ignition .
    Mar 2020
    in the field
    does the system relay start after pressing the start button? nr14?
    Mar 2019
    east nord pole
    Quote Originally Posted by pawl View Post
    No Sound and no start reley when i push start buton , no ignition .
    No. No sound at all. Were is nr14 relay please
    Mar 2019
    east nord pole
    I have this car in an Workshops and i didn't ask special to lisen relay no 14 , they told me to by GEM Module or confort Module.
    Now i buy it and tomorow they try to Transfer date Form org to donor.
    I try gem module. But car is still the same
    Mar 2020
    in the field
    I used to have a problem and the dead kuga was a broken wheel during a collision, after repairing the abs sensor, everything returned, I do not know if a failure of some security system does not block the start function, there was also no steering lock reaction,kuga 2010.jpg
  13. #13
    Mar 2019
    east nord pole
    Today i change the Gem module , write all data in donor wich was the same code .
    But car still no ignition and no start .
    Car see bouth key , but i still have this error .
    What can be the problem with this kuga ?
    Best regrads
  14. #14
    Aug 2018
    Romania
    At an old KUGA (2009 - 2010 I think), I encountered an ignition problem due to the only relay on the relay and fuse panel in the luggage compartment. There are also 1-2 fuses, with keyless connection.
    The relay in the luggage compartment (ignition) must be in the same condition (open or closed) as the relay under the hood (ignition).
    Do not forget to press Thanks and Reputation buttons!
  15. The Following User Says Thank You to sebage For This Useful Post:
    catalinosonesti (30th May, 2022)
  16. #15
    Mar 2019
    east nord pole
    When i put ( + ) to fuse 114 dash lights are on , clima also ( no ventilation) and i have this error .
    The car no ignition working and i think all this Happen till i want to put big Navigation even the conection like the same .
