Results 1 to 9 of 9
    Apr 2022
    Default Vw tiguan climatronic module fix help
    Please can you help me out..I have vw tiguan climatronic module..
    The problem is the heater blower not working..and I did scan look bellow vcds log
    Some say replace it..but iv opened it up I see 93c56 eprom and MB90F94A mcu look bellow can this module be fixed?
    Sent from my SM-A226B using Tapatalk
    Portugal
    Have you tried running the fan with direct current?
    When selecting the speed, does current come to the fan?
    According to the fault codes, you have a lack of gas in the A/C system, it could be a cause of the fault and the basic adjustment to the floodgates is not done.
    Sep 2013
    garage
    hardware ....wires...not soft...buy a used module
  4. The Following User Says Thank You to Mr BLACK For This Useful Post:
    Nazo (14th July, 2022)
    Oct 2017
    99problems
    Check fuses, module from the blower, check resistance from blower. Probably is the blower defective.
    Is not a software problem, is a hardware one.
    If I helped you, please don't forget to hit :
  6. The Following User Says Thank You to ilzul For This Useful Post:
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Check this PWM driver for motor.
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
  8. The Following User Says Thank You to raceshadow For This Useful Post:
  9. #6
    Apr 2022
    Quote Originally Posted by rui View Post
    Thanks rui..I was told the vehicle went to some workshop and they said it's module problem..
    I will to test as you said above Thanks
  10. #7
    Apr 2022
    Quote Originally Posted by raceshadow View Post
    Thanks raceshadow..but were is this PWM module located?
  11. #8
    rafal's Avatar
    UK - PL
    is mounted with blower......................
    need help
    now my goal is to buy xp-005
    who will help?
  12. The Following User Says Thank You to rafal For This Useful Post:
  13. #9
    Apr 2022
    Quote Originally Posted by rafal View Post
    Big thanks rafal I will look into it
    Thanks given to all you guys
