Results 1 to 10 of 10
    rrador's Avatar
    Feb 2011
    Tamo daleko
    Default 2022 Toyota Camry impact sensor initialization error
    Hi I have a 2022 Camry.
    Car had impact on passenger side door.
    I reset airbag module and have these codes now.
    B1613 Right front airbag sensor initialization error
    B1618 Left front airbag sensor initialization error
    B162C Side airbag sensor assembly 2 right initialization error
    B163C Side airbag sensor assembly 2 left initialization error
    B1633 Right curtain shield airbag sensor initialization error
    B1638 Left curtain shield airbag sensor initialization error
    It is not module issue. I have another 22 camry here with no accident and tried swapping modules and still have same codes. And this module works in the other car.
    Impact sensors are all original. We checked all wiring everything looks good.
    Tried unplugging all the sensors, still have same codes.
    Very strange issue. Does anyone have any ideas?
    superjet's Avatar
    Aug 2018
    Which car of the switch module reported a fault? If it turns out that the car is still reporting faults, it's obviously the car's problem.
    check wirelines.
    If the module is installed in the car and it reports a faults, it is the problem of the module.....
    fuzz1's Avatar
    Jul 2019
    2022 car still under warranty i guess if it's just a door that has been in collision. Unless it's totaled then i guess it's more than a door
    rrador's Avatar
    Feb 2011
    Tamo daleko
    Quote Originally Posted by superjet View Post
    check wirelines.
    Module is good because worked fine in other car. And other module in this car report same faults.
    Wiring all checked everything is good. Codes are for every crash sensor in the car. It really makes no sense.
    rrador's Avatar
    Feb 2011
    Tamo daleko
    Quote Originally Posted by fuzz1 View Post
    car was insurance write off so no warranty. Passenger front door was replaced and had curtain airbag and seat airbag blown plus front seatbelts.
    renia1983's Avatar
    Jun 2022
    did u checked wiring from each sensor u get fault of to module itself for continuity? it looks like some connector might be same for all of those modules and it's disconnected.
    rrador's Avatar
    Feb 2011
    Tamo daleko
    Quote Originally Posted by renia1983 View Post
    Yes all wires good. There is nothing in common for all those sensors.
    fuzz1's Avatar
    Jul 2019
    Did you solve this issue?
    The collision sensor wiring is reversed.
  10. The Following User Says Thank You to bolonc For This Useful Post:
    fuzz1 (19th December, 2023)
  11. #10
    fuzz1's Avatar
    Jul 2019
    In my case the sensors were damaged
