Results 1 to 15 of 23
    May 2022
    Default Immo off instrument cluster
    hey
    bought another used instrument cluster for octavia 2007 but can't use it because it is immobilizer active
    is there anyone willing to help me
    rafal's Avatar
    UK - PL
    off in ecu m8 ........................
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    dooms (21st July, 2022)
    May 2022
    hey rafal
    Are you sure i asked on another site where my immobilizer is and everyone says in instrument cluster
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Quote Originally Posted by dooms View Post
    hey
    Yes, is it in the intrument cluster, but here you can not make immo off. Only in engine ECU. Or copy immo data from old to new cluster. (FVDI a and next)
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
  6. The Following User Says Thank You to raceshadow For This Useful Post:
    Oct 2020
    Bulgaria
    yes, your immobliser is n the cluster, you should adapt your new dash, or make immo off in ecu. instrment send message to ecu to start engine or not if you have problem with immo.
  8. The Following User Says Thank You to evgeny87 For This Useful Post:
  9. #6
    rafal's Avatar
    UK - PL
    hey rafal
    if you are asking where immo is stored and how system of immo is builded in car - change job or don't touch this car
    need help
    who will help?
  10. The Following 3 Users Say Thank You to rafal For This Useful Post:
    danielif (21st July, 2022), dooms (21st July, 2022), Mr BLACK (21st July, 2022)
  11. #7
    May 2022
    thanks for your answer rafal but how can i learn if i can't ask
    you never started from zero
    grts
  12. #8
    Sep 2013
    garage
    what tools do you have mate ...? yes in most vag group cars immo is in dash ...if you do immo off in ecu you have SAFE on dash(used dash) ..so you must buy some tools to do the job
  13. The Following User Says Thank You to Mr BLACK For This Useful Post:
  14. #9
    May 2022
    My tools that I have already bought but nothing works
    ObdlinkSX
    Vag key login
    Vag-k-line commander 1.4
    vag-can-pro5.1
    Autophix 3210
    Achate t41
    carista
    Vas6154 With odis 7.2 and odis 12
    Rosstech Hex-2 with VCDS original
    driver box edc15/me7
    ezp2019+
    ch341A
  15. #10
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Read pin code from new dash with tool . Read pin code from ecu or old dash.
    Use VCDS adapt used dash to car. All this you have on ross tech web . Programm key and start car .
    Follow instructions on ross tech mate you have tools to do that.
    Send from my TELETEXT
    Here to HELP!
  16. #11
    May 2022
    Hey immokill
    that's just the problem of the used instrum cluster I can't get the pin from eeprom 24c32
  17. #12
    Volker's Avatar
    Maybe the cluster is damaged?
    Can you post dump?
    CMD | Alientech K-Tag | Batronix
    +++ NO Passwords +++
    Just press THX & Rep if i helped you....
  18. #13
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    check your instrument, if is in two pieces, the back pcb is the immo, just exchange it.....
    whats the problem of the ori cluster?
  19. The Following User Says Thank You to Panathaole For This Useful Post:
    Mr BLACK (22nd July, 2022)
  20. #14
    May 2022
    here's the file I was able to read from the instrument cluster used
    i can read the chip of the two insttrument but have no program that can read them have 2 file 1 from old and 1 from new used cluster
    i would have to change my vin in the new cluster and change odometer too old has 248310 miles and new 187580
  21. #15
    May 2022
    Hi Panathaole
    the instrument is in two parts and eeprom on the back part is a 24c32 chip
    the reason i want to put other instrument is that lcd screen becomes blurry
