I know it's not listed as readable officially by UPA but has anyone successfully read or write infineon tri core chips using UPA? The TC family tri core chips
Thank you
Thank you
Hi buddy
I think infenion tricore chips are easily readable and writable. I regularly read and write ford airbag modules with TC222S-16F memory chips with CG100. And cg100 is a very basic tool. Mine is 2018 edition. So i hope upa can read them.
If needed, share the module images in pm and i can share the chip connections and pin outs of the module.
All the best
Sent from my vivo 1723 using Tapatalk
fuzz1 (28th July, 2022)
Hello
Unfortunately TC chips are not officially supported by UPA. I know some tried without success reading them as xc chips
what does that mean "officially" ?
There are no updates from 2021, there are no TC in the list.
Hi fuzz
Share the module images you wish to read Buddy. I will share with you the connections. and if i have, then i will share clean and tested files of those modules . Connect the module like that and try reading or writing them as some other chip. May be it works by chance
fuzz1 (31st July, 2022)
Thank you. I will keep the proposal for help open.
I don't have any specific modules to read right now. However i get the feeling it shouldn't be too difficult to read TC chips with UPA. Someone with programming background would surely be able to do that
Hi there, i have an Infineon Tri-core to read, it is a SAK-TC1762-128F66HL, anyone can read this chip with UPA?..
Here is an image of the chip.
Thanks.
anyone come across a good reader for this chips, as im struggling with vvdi prog
