Results 1 to 2 of 2
    Default daihatsu materia immo problem
    Hi mates,
    The battery of this car was disconnected for almost 2 month and now the car does not start anymore.It is 2008 daihatsu materia 1.5 16v motor code 3sz-ve
    I have tried the following:
    1.disconnedted the battery for 30 minutes but it did not work(immo keeps blinking)
    2.I have programed a new tranponder but it still the same
    3.by obd shorted pin 4+13 for almost an hour also it still the same,
    I believe that synchonization between ecu and immo is fauly.
    Please I need your help either to repair synchronization or immo off or maybe a good paired files so I can make a new tranponder.
    Thanks in advance,
    Best regards.
    here is also the original key and ecu fault code
