Results 1 to 10 of 10
    szkeptmen's Avatar
    Jan 2010
    Hungary
    Lightbulb 2003 Citroen Xsara - economy mode
    Someone know, why it's in economy mode permanently ?
    It seems, no way out...
    Valeo bsi with 95040 eeprom.
    THX + REP
    Polak, wegier dwa bratanki i do szabli i do szklanki
    Oktawian's Avatar
    Sep 2016
    Did you connect 2nd working car with cables ?
    From what i remember Launch had option to turn off economy mode
    szkeptmen's Avatar
    Jan 2010
    Hungary
    Yes, I have Launch, but unfortunately doesn't help...
    Dec 2009
    UK
    Are you saying it's in eco mode with the engine running? Is the alternator charging the battery?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by szkeptmen View Post
    Hello, it will help to connect the power supply and increase the battery voltage
    PLEASE PRESS THE " THANKS " BUTTON
    Dec 2009
    UK
    Quote Originally Posted by gwiazdamb View Post
    Battery voltage or condition has nothing to do with eco mode on this model.
    szkeptmen's Avatar
    Jan 2010
    Hungary
    Quote Originally Posted by the_big_d View Post
    No, the car doesn't start...
    fred77's Avatar
    Jun 2019
    ...now we are told.
    economy mode is least of your worries!
    Solidarity with Ukraine
    Dec 2009
    UK
    OK you need to start the engine otherwise the BSI will never come out of eco mode, eco mode has triggered because certain consumers have been on for too long without the engine running (normally the ignition switched on in a non starting situation). The BSI will come out of eco mode once you get it started.
    Eco mode is not stopping the car starting, the car is in eco mode because the car is not starting. Basically just ignore eco mode & treat it like any other non start situation.
  10. The Following User Says Thank You to the_big_d For This Useful Post:
    szkeptmen (22nd August, 2022)
  11. #10
    vialli's Avatar
    Aug 2018
    Romania
    If you have the PIN, you just have to reprogram the keys and it will start
  12. The Following User Says Thank You to vialli For This Useful Post:
