Results 1 to 4 of 4
    Aug 2022
    Default Renault Master 2007 2.5dci dont work good
    Hi, I have written a Master 2.5 dci 120 MY2007 with kessv2 clone to make stage 1
    Supported Injectors and everything OK.
    When the engine starts, after one second the engine stops. I say wait is strange
    DF053 Rail Pressure Regulation Function.
    1.DEF. upper limit exceeded.
    Freeze data:
    Engine: 611r.p.m.
    Rail Sensor: 1782,70bar (max. sensor value)
    Demand ecu rail pressure: 311bar
    Original file is written by EOBD again. Same error.
    When im doing the diagnostic is one error is writing
    Rail pressure regulation function
    Above the max level
    So, i dont touch nothing just obd for read and write
    If i will try with another rail pressure sensor. I am sure will be the Same error, same values. Because im not the first with this error at this Forum
    Now what can I try please ?
    Does anyone know a similar problem?
    Regards
    Jun 2022
    Switzerland
    before you flash the car with kess did you have this problem or not and if you have flashed your car with stage 1 what happens if you upload ori file..... give us more detail
    Jun 2013
    Lithuania
    "Rail Sensor: 1782,70bar (max. sensor value)
    Demand ecu rail pressure: 311bar"
    Pretty sure you lost EEprom data when writing. This happens with these when writing via OBD, then rail pressure goes to max, the fuel pressure regulator type changes... If you made before writing an injector read (Kess special function) try writing it (special function, injector write). If no success need to write virginized EEprom and code injectors, configuration (at least what I would do).
    Senior Member Novik_UA's Avatar
    Jun 2010
    With Can Clip or possibly Launch you need to change type of fuel pressure regulator, and all will be ok
