Results 1 to 15 of 17
    PSAcars's Avatar
    Oct 2015
    HOME
    Default Renault scenic 1.5 dci ECU swap
    Hello to all. Please help with this problem. Original ECU has damaged pin connector ( rust ). For donor ECU, I copied the 95080 and 29f200 from ori to donor ( with programmer off board ) now car is starting but, no throttle control. With old ECU I have throttle and car is working Ok ( some time it is not starting and I have to knock the ori ECU 2-3 times and car starts). The ECU lith lable M9 is the original ECU, what am I missing or ECU is not the same like Donor????
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Is there any info that needs to be transfered from old to new sak-c167cs main CPU ????
    Apr 2021
    Belarus
    What programmer copied the flash? Are there errors in the ECU donor?
  4. The Following User Says Thank You to meser75 For This Useful Post:
    PSAcars (30th August, 2022)
    PSAcars's Avatar
    Oct 2015
    HOME
    29F200 copied with tl866, Willem. When I start car with donor ECU I have message on dash ( electronic fault, engine overheating ) in diag I have no faults.
    Apr 2021
    Belarus
    If you disconnect, for example, the MAF, does the ECU donor register an error?
    Apr 2021
    Belarus
    Quote Originally Posted by PSAcars View Post
    Cooling fan actuated? What temperature in actual parameters?
    Are you diagnosing with Clip? Maybe try some adaptations?
    PSAcars's Avatar
    Oct 2015
    HOME
    The most interesting thing is that the 29F form ori and 29F from donor ECU are 85% different. If I search online the ori ECU with all numbers it is Nisan Micra K12 1.5dci, and for donor ECU the numbers (all numbers ) are for Renault Mmhhh.
    In donor ECU with donor flash, ECU is starting but no throttle control, in ori ECU with donor flash dump car is no starting at all, even no starter motor is running.
    Apr 2021
    Belarus
    Attach files.
    It may be possible to make the donor's ECU virgin.
    Or if this is a Nissan system, it is possible that the immo<->ECU will be synchronized automatically after rewriting the keys.
  10. The Following User Says Thank You to meser75 For This Useful Post:
    PSAcars (31st August, 2022)
  11. #9
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. This are original and donor 95080 and 29F200 files.
  12. #10
    Apr 2021
    Belarus
    Can you read the ISK from the UCH? It can do Clip or Renolink.
    Or read eeprom from UCH.
    Let's try to transfer the immodata to the ECU donor.
  13. #11
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Here you go.
  14. #12
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i think you have clone and the micro too....
    here is virgin of the donor ecu, auto sync in ign on...
    Yavor DONOR ECU 95080_virgine.rar
  15. The Following User Says Thank You to Panathaole For This Useful Post:
    PSAcars (1st September, 2022)
  16. #13
    Sep 2013
    garage
    i do some ecu like this ...ac not working ( gnd for ac presure sensor) and i use same part nr and swap eeprom and write injectors and working ok
  17. #14
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Something strange happened today with car. After I wrote 95080 with virgin dump install on car and try to start up. No starter crank. After 10s on ignition, dash went googats, no card detection, no esl sounds, no nothing. After 5 hours of xxxxxxxx I wrote eeprom backup to uch and car started with old ECU from firs try. Will continue work next week.
  18. #15
    Apr 2021
    Belarus
    Try to write this dump to the ECU donor.
  19. The Following User Says Thank You to meser75 For This Useful Post:
    PSAcars (3rd September, 2022)
