Originally Posted by
edge77
Hey guys!
i wonder if someone came across a similar issue!
After flashing dpf off, car did not start, but would crank and do diagnostics.
Returned back to original backup, car started and everything was ok.
My file source send me new file, tried again, car started twice, no errors, all seemed ok, but at 3rd try no more starting, but would crank.
Returned back to original, everything ok again.
3rd files comes up, developer said change bit, flashed to car, no start or crank...damn...
Then i tried Diagbox, can even see vin, or connect to any module...not good.
Flashed back original like before, the result was the same, no start, no connection to any module...
Noticed that car doesnt lock doors anymore, only folds mirrors when pressing key fob
Tried to check evey fuse, bsm, bsi, all good.
Ecu on bench works ok, read and writes perfect.
Car switches on ignition, esp and abs light, battery light, and engine error on screen.
Please help!
ECU MD1CS003
Thanks to all.
