Results 1 to 2 of 2
    Default Suzuki Ignis 2002 key programming
    have a Suzuki Ignis 2002 with a OEM key from dealer.
    car is EU made but car is in barbados.
    now dealer overthere cant program the key because they cant get pin through internet because of continental differents.
    is there away to get pin code from VIN so we can program the key?
    Oktawian's Avatar
    Sep 2016
    Ignis and Swift should be the same cars i guess.
    You can try this pin as well :
    "Problem solved. I used a suzuki tech2 device. First i paired the ecu and immo, after that i erased the key and programmed it again. How it worked. I set the tech2 date to feb 2004 , used 890625 first password and 0895 second one . My Tech2 sw version is 01.240.022 . I hope that this info will help someone. Don't try to make immo off using another files from DK or to remove the immo eprom or put FFFF or 0000 , because it does not work."
    And here is something from @Rapido
    "swift on 05 is a cross over between 2 systems , old 4c system uses a set pin code of 0895 on swift , the id46 system uses set pin code of 0408 normally on swift , most good programmers know the preset pin so no need to enter , if your machine is asking for pin code it should be one of these 2 pins."
  3. The Following 2 Users Say Thank You to Oktawian For This Useful Post:
    danielif (20th May, 2023), vageric (6th September, 2022)
