Results 1 to 8 of 8
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Default VW Passat 2.0TDI DPF OFF
    Hi, does anyone have working solution for DPF OFF on this ecu PPD1.2
    Many auto solutions I have tried doesn't work, unlcuding Davinci
    Chiptuning File Service 24/7
    Thanks+Rep If I helped you!
    rm23's Avatar
    Dec 2009
    UK
    i will help you, davinci won't work on that ecu...
  3. The Following User Says Thank You to rm23 For This Useful Post:
    Johnsy1998 (27th September, 2022)
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    PPD is a disaster for DPF off. All sensors MUST be working. DPF off requires DPF to be reset with diagnostics on original software.
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Im using VAGCOM but in order to reset DPF i need to login with pin code on sercurity access - 16
    How can I find the code please
    best regards.
  6. #5
    Max001's Avatar
    Sep 2018
    Italy
    You can use a generic diagnosis like Delphi Brainbee Autocom .. to do dpf replacement
    File Service Dpf Egr AdBlue Dtc Tva Swirl Kat Off and more
  7. #6
    rm23's Avatar
    Dec 2009
    UK
    drive the car on my file, car must be out of limp mode now and dpf light will go away itself after test drive, if all your sensors are ok enjoy
  8. The Following User Says Thank You to rm23 For This Useful Post:
  9. #7
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Quote Originally Posted by Johnsy1998 View Post
    best regards.
    DPF off requires DPF to be reset with diagnostics on originl software. Ensure all ash counters are reset. Write modified file, then drive the car for 20mins. The DPF WILL go out. If DPF light present on dashboard post remap, then needs diagnostic work. No drilling but complete removal on Siemens PPD. Always check live data reading with VCDS (measuring blocks 067 and 075). DPF pressure needs to be way below 10 mbar on idle (ideally 1 mbar on idle). Ash counter resets on mod file only drop DPF ash counter to 20% hence it needs to be driven for 5 miles to go down to 0%. When it reach 15% DPF light goes off. Check all DPF pressure sensors working, and not giving false values from broken sensors.
  10. #8
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    All fixed now, thank you everyone for your comments and @rm23 for you file.. works great! not very often I do work with PPD ecu's so thank you very much.
  11. The Following User Says Thank You to Johnsy1998 For This Useful Post:
    rm23 (27th September, 2022)
