Results 1 to 4 of 4
    Top Poster Kinred's Avatar
    Oct 2015
    In the Jungle
    Default e90 msv70 to cas3+ lost isn
    hi
    i arrived a bmw with engine swap and ecu (msv80 to msv70) after locksmith manipulation of data car are a lot of immo related codes from cas module, the actual situation is this: eeprom from msv80 (ori ecu) is lost, ISN lost on cas3 but have a one working key, msv70 apparently is ok. Question, is possible make ISN from msv70 to cas3? i attached msv70 eeprom and cas3 eeprom
    Thank You
    May 2017
    You can swap between MSV80 and MSV70...
    Got MSV80 and sync with CAS... relearn keys and do the coding for PC... if its 6HP... reset 6HP and sync also.
    How do you lost isn? Just can happend by bad programming.
  3. The Following 2 Users Say Thank You to Lambda1 For This Useful Post:
    Kinred (27th September, 2022), s qubiak (27th September, 2022)
    Oct 2015
    In the Jungle
    Quote Originally Posted by Lambda1 View Post
    msv80 is from ori blowned engine and eeprom is lost gearbox is GM
    Thank You
    Oct 2015
    In the Jungle
    "How do you lost isn? Just can happend by bad programming"
    I have no idea the car is at 900 miles and it arrives after they can't do the job
    Thank You
